Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Unable to turn mixer on
I recently received a KitchenAid stand mixer 325 watts Artisan mixer.
I can lock and unlock the arm up and down, but I can not get it to turn on. I did confirm the arm was in the lock postition, but when I try to turn it on, it will not budge from the off position. Is there some silly safety thing that is engaged? I read the guide and did not see anything.
Thansk
  • 700 Answers
You have to have the bowl installed correctly and all the schields in place before the unit will work
Posted on May 21, 2009
It doesn't start
Check the fuse, and the bowl should be in place
Mar 26, 2013 | KitchenAid Artisan Ksm150pser 325 Watts...
How much does it cause for me to buy this mixer?
After looking at several sites the mixer ranges from around the 300.00 range some have it for 240.00 this link has it advertised on Ebay for 185.00 http://www.ebay.com/ctg/KitchenAid-Artisan-KSM150PS-325-Watts-Stand-Mixer-/69779042 . If you were to buy the mixer new from a store it would run you around 340.00. if you have any further questions message me back Thanks
Rick
Sep 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
What is the difference between the Kitchen Aid "KSM150PSMC" and the KSM150 ?? thanks
The KSM150 is the line of mixers with similar features. It is in the Artisan series, tilt head, 325 watts. All mixers in the KSM150 line have the same features.
The one that you asked about, the KSM150PSMC is done in metallic chrome.
Best regards, --W/D--
Feb 01, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I have a KitchenAid Artisan stand mixer (325 watts/model KSM150), about 5 years old. Lately, when mixing dough for bread or cookies, the motor head of the machine wobbles a bit from side to side. In...
the solution to this is to tighten the screw visible through the base that intersects the pin. Turn the machine upside down and using a long flat screwdriver tighten the screw.
Feb 20, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My 325 Watt Artisan mixer's adapter won't come off? How do I get it unstuck?
To remove the mixer attachment I belive you must press up on the attachment to lock the inside gear into place. Once it is locked into position you can now twist to the left to remove the attachment. once removed you can pull the shaft back down to unlock the gear.Hope this helps.
Thanks.
Nov 15, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Dome and blade assembly for kitcenaid ksb5bu blender
Your exact model number for your cobalt blue artisan mixer is KSM150PSBU1. the dome and blade assembly must be a attachment part. and i will need a better description before i can narrow down what it could be.Hope this helps
Thanks
Sep 11, 2009 | KitchenAid KSM150PSGR 325 Watts Stand...
Mixer switch is locked
If this is a 325 watt Artisan, there is no safety switch I know of unless its in the circuit board. Your mixer is broke.
Mar 01, 2009 | KitchenAid KSM150PS Artisan Series Stand...
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
366 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
