Question about Sunbeam Home
Dual cord for PAC 0595 - Sunbeam Home
The 2 controls to our electric blanket are flashing "FF". What does that mean, plus there's no heat at all from it.
With the Sunbeam blankets that I have owned, FF meant that there was a bad connection somewhere. Have you tried the unplugging and replugging the Controller cord back into the blanket? Make sure it is plugged in GOOD AND TIGHT. If that part is connected as tightly as it can go, you may have a defective element.
Dec 18, 2014 | Sunbeam Pac 259 Dual Electric Blanket...
Can a split white cord on ms pacman tv game be repaired
Absolutely, if your not electrically inclined take it to your local electric repair shop. It shouldnt cost much,
Jun 03, 2014 | JAKKS Pacific Ms. Pac Man Plug And Play Tv...
Charging cord missing
The charger manufacturer is Clore Automotive. The part number is ESA26 (http://www.cloreautomotive.com/sku.php?id=274).
If you know anything about electronics, you can determine the input voltage and current requirements for the charger and purchase a generic power pack. The cord connection to the charger can be matched and purchased from an electronic store like FRYs.
Oct 24, 2012 | Solar ES1224 Truck PAC 3200 Peak Amp,...
Power cord
I couldn't find the power cord at part store, encompass parts, pac parts, or ued.net
I didn't try Andrews Electronics in California and I am not sure I went to the correct Fox International in Ohio.
Try calling
(800) 877-5036 EXT. 1485
Feb 05, 2011 | Sanyo DP50747 50 in. Plasma TV
I have a xdvd700 dual and want to bypass the brake thing but no remote is there anyother way?
Usually there is a handbrake connection that needs to be grounded to the chassis in order to bypass the screen lock. I normally wire it though a switch to ground and back to the handbrake, so if the car is inspected it works like it should.
Some units feature a footbrake wire that needs to be pulsed as well. This is harder to override. I use a bypass device from Peripheral called the PAC-TR7.
Dec 06, 2009 | Dual Electronics XDVD700 Car DVD Player
How to intall PAC SWI-PS green and blue wires to pioneer AVH-P4100DVD
I don't think you install the green and blue wires to the actual deck itself you just plug the aux cord from the pac into the back of the deck the otherwires depend on your car
Nov 22, 2009 | AudioControl PAC SWI-PS - Pioneer and Sony...
Delonghi pac w160a...''no water symbol'' stops on in airconditioning mode even though water tank is full
In the back of these units where the cord pulls out, there is usually a red reset button, try pushing that to reset the unit, also make sure the filter is clean, pulls from the top out of the unit. Make sure the coils are clean as well behind the filter.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 12, 2009 | DeLonghi Air-To-Air Portable Air...
Plug is broken
You can buy a new Durabrand Dual car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand Dual 7b portable dvd player
You can buy a new Durabrand Dual wall ac adapter by clicking on the hyperlink:
buy replacement wall ac adapter power charger cord for DURABRAND Dual 7b PORTABLE DVD PLAYER
Jun 20, 2009 | Durabrand Portable DVD
Home Logo
32 people viewed this question
Top Sunbeam Home Experts
topcat7736
Level 1 Expert
gbob59
Lawrence Oravetz
Are you a Sunbeam Home Expert? Answer questions, earn points and help others
