How to change picture size
My Toshiba flatscren changes picture size every time I turn it off how can I set it to one size
2 Suggested Answers
SOURCE: Picture won't change sizes
If you are using a cable box, the settings you want are in the setting menu under "format" or "display" . Typically the choices are Normal or stretch, Select stretch.
The "small picture is how the old NTSC format displays in "normal mode" on a High definition set.
While you are in the settings menu, you might want to verify that the box is set to output at least 720P if not 1080i.
www.mcveyelectronics.com
Posted on May 03, 2009
Cant save picture settings toshiba ct 90164
There may be an active lock for setting changes. Look through the settings of the input device and check whether that has got changed.
Aug 02, 2012 | Televison & Video
How do i change my pictue size using remote control
Hello
To select the picture size using the remote control
Press "Picture Size Button" on the remote control
While the Picture Size screen is open, you can do one of
the following to select the desired picture size
Repeatedly press "Picture Size Button"
Press the corresponding Number button (0-6) while the
Press UPor DOWN button, while the Picture Size screen is open
Using these functions to change the picture size (i.e.,
changing the height/ width ratio) for any purpose other than
your private viewing may be prohibited under the Copyright
Laws of the United States and other countries, and may
subject you to civil and criminal liability
OK
May 11, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
The picture size resets when the tv is turned off then on.
It also resets when you switch to a different Input... IF you have the Auto Aspect Ratio set to On! To set the Picture Size so that it won't change back each time, switch to the Input you wish to change (you'll have to do this for each Input separately), then go to- MENU > Picture > Theater Settings > Auto Aspect Ratio > and set it to Off. Once you've done this, your Picture Size setting will remain, even after powering off, or switching inputs ;)
Oct 23, 2010 | Toshiba 32E200U 32 in. TV
How do i adjust the picture to fit the screen?
The wide button on your remote adjusts the picture size. Each time you press it you adjust the picture. If repeatedly pressing the wide button is not changing the picture size check you cable/satellite remote control. Look for the hdzoom# button. There may also be an aspect or format button. When you adjust this the picture size changes and between the Sony remote and the cable/satellite remote you should be able to come to a happy medium. If the picture size still isn't changing you might not be set to the correct resolution i.e. 1080i on your cable/satellite box. It might be set too low or you might be in the wrong input (av 1 av 2 hdmi 1 hdmi 2) etc.
Jul 07, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How do you change picture size without the remote control
I have a 47 inch Toshiba lcd tv. I lost my remote control and am unable to change the picture size on the screen. Is there a way to change the hd settings from 480i to higher definition through my digital cable box?
Feb 28, 2010 | Toshiba 37WLT58 37 in. LCD TV
How do I change the screen size on my Toshiba 26AV500U. Example: On CNN I can't see what is scrolling across the bottom on the screen.
The "PIC SIZE" button on the top of your remote will change the picture size. Keep pressing the button to find the screen size you like and works best.
May 13, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Apr 07, 2009 | Toshiba 42HL167 42 in. LCD Television
I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS.
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
Jun 02, 2008 | Canon Cameras
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
