Question about Whirlpool Refrigerators
Whirlpool conquest refrigerator, ice motor/bucket won't snap back on
I removed the ice bin and crusher part to remove large chunks of ice freezing up the auger. Now it won't snap back on. It looks like the serrated fitting is lined up with the metal knob sticking up on the door and the blue latch is disengaged so the plastic parts line up. My husband squirted WD40 on both metal parts. Now he is getting a file to see if there is a bur causing it not to slide back on.
Greg20
  • 149 Answers
SOURCE: In side by side whirlpool refrigerator freezer ice cubes stick
if they are hollow and stuck together then u are not getting enough water..check the supply.
Posted on Jun 11, 2009
SOURCE: ice crusher does not turn
Sorry, the part number is KSRS271kss01
Also says "superba" on the front
Posted on Oct 19, 2009
SOURCE: know how to put the ice bin latch and spring back together
I had the same problem. When you put the spring back on the little arm towards the button, use a mini screwdriver or something to pull the spring back and pop the latch part back in the indented spots. Then, it will seem stuck but you just put some pressure on the curved side of the latch - opposite from the button and it will "pop" back into place.
Posted on Nov 06, 2009
  • 1891 Answers
SOURCE: Whirlpool 2211590 Ice Auger Conquest 2-door
If the ice will not go down the delivery outlet. the the augar will have to work harder than .normal .. try drying the out the delivery area // then use a food grade silcone and spray this . this may correct problem .. . also ck the seal on the door if bad it will let mosture in and cause poor delivery .. hope this helps mm. feed back pls ..
Posted on Jul 10, 2011
  • 8 Answers
SOURCE: Despenser door opens, crusher motor doesn't work
My ice maker quit dispensing too but the water worked and makes plenty of ice.
I read several fixes with auger motor and the red herring was that I had been working on the house and the circuit was off to the refrigerator. So I thought it might have been melted ice sticking the motor. Turns out that while it was off someone must have wanted ice really bad and pushed really hard or just happen to be time for the plastic retainers that hold the micro switch in place to break. I have a ED5PHEXRT00 Whirlpool and the control bracket is what I have to replace. You have to pry the front cover off from the bottom where there are some screwdriver slots, pop off to expose the controls and bracket. Micro switch was still good. Just ordered the part for 14 dollars plus shipping and tax.
Posted on Feb 29, 2012
Whirlpool GD5RVAXVY05 dispensing problem
yep replace the motor and she is back to normal
Mar 22, 2014 | Whirlpool Refrigerators
Whirlpool side by side ice storage bin will not go back into place due to the auger
I had this exact same problem. After a difficult removal of the ice bucket (admittedly a lot of yanking against frozen ice cubes before I decided to chisel them out from above), I could no longer seat the ice bucket back onto the hexagonal auger drive shaft. When activating the ice dispenser, I could hear the motor turning, but the auger shaft itself would not rotate. The cause was that the auger shaft had moved upward through its stop grommet during all of the yanking to remove the ice bucket.
Take off the two hex screws holding the top plate around the auger shaft. The shaft is then easily removable and you can inspect it for slippage against the stop grommet. In the attached photo, you can see there is about 1/2 inch of clean auger shaft visible above the grommet, where the shaft has slid upward relative to the grommet. If this is the case, the fix is simple. Turn the shaft upside down and lightly tap the grommet around the edges with a small hammer until it moves back into place. Upon replacing the auger shaft, you can feel it seat back into the drive motor adapter.
Jun 30, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
WILL NOT MAKE SWITCH FROM CUBE ICE TO CRUSHED I CE
remove bucket,empty into large bowel. inspect bucket opening,and be sure ther are no chunks of ice hindering movement of blade bypass mech. w/bucket out operate ice disp on crushed and cubed selections,listen for sharp snapping sound before motor turns.if sound is heard,reinstall bucket,and you should be good to go
Mar 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My icemaker is making huge chunks of ice in bin
You will need to replace the termination thermostat. What sounds like is happening is. Every 8 to 10 hr. your freezer goes into defrost for a set period of time. There is a termination thermostat that senses the temp at you evaporator coil in you freezer. When you heaters come on they defrost the ice from your coil. once the termination thermostat senses the temp has gotten to a preset degree, it cuts the power to the heaters. This keeps the heaters from staying on the whole period and making your freezer warm. After the pre set time period the timer turns the compressor back on. What it sounds like is happening is the termination thermostat is not opening, cutting the heaters off. By not doing so, it's letting your freezer get above freezing, melting your ice some. When the timer advances into cooling again it freezes your ice together. I would say it's your water valve leaking but that would make large pieces of ice that the ice maker has trouble dumping and also sometimes a large chunk that does not look like cubs. That would also eventually freeze the inlet tube closed..
Please rate solution
Aug 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker makes Ice But doesn't dispense it.
Had same problem. Looked everywhere and found no solution i'm a not a repairman...they probably do not want to post so they can make 150 for a repair visit. At least try this first it may save you $$. Remove ice bucket from freezer. Remove 2 screws @ auger...remove cover and auger ....remove spring and large hex shaped shaft. heat the large shaft end with a torch and put it back in hot side toward motor until the motor end is not frozen. No torch you can use hot water...but that may freeze again.
This was happing because my flap to the ice was not closing all the way .
Manual for parts can be found here it shows ice maker parts on page 7.
Good Luck Kono
Aug 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Jun 09, 2009 | Refrigerators
The bin on my ice maker forms big chunks of ice
check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice, OR cause the thaw-freeze cycle resulting in chunks. Check your door seals and thermostat, repair/replace as necessary.
May 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker Makes ICE, But it will not Fall
Replace the ice maker sounds like the thermostat in the ice maker has shorted out
Dec 20, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
51 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
