Question about Locks & Locksmithing
Cannot open Safewell 250BESK
Code now does not work
Safewell EX2005327788
A set of emergency keys is supplied with every Safewell safe. In case the batteries drain out, you may use the emergency key to open the safe. These keys override the digital password. Remember, never keep the emergency keys inside the safe.
Jan 14, 2015 | Home Security
I put in too many codes. Now, my safewell deposit box won't open
try using the manual key to open it or you will have to contact a locksmith to open it
Nov 27, 2014 | Home Security
I have the keys of my safewell but I forgot the combination.. How can I open it? Help me plz. The model is YB-350A
There is no such thing as a general code to open safes. So the only thing you can do is write down all codes you ever used, and try thm one by one. Sorry, but if there was any "backdoor" in a safe, the code should be useless.
Jul 27, 2014 | Home Security
Have a safewell electronic system safe ex2007126498 want to open it lost key and forgot the password
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the codeicon1.png as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Apr 22, 2014 | Computers & Internet
I hv a safewell safe. i locked the emergency key before setting my personal key inside the safe. how to open the safe now?
You'll most likely need help from a locksmith. Basically, the lock can be picked, to get the safe open. There might also be a factory pre-set code.
Aug 16, 2011 | Locks & Locksmithing
I forgot the safewell electronic code and didnt have the key
won’t work.
ELECTRONIC SAFES
electronic keypad –159B. (These numbers are preset. You should change the code as soon
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
knob so you can turn it and retract the live action locking bolts.
Good luck
Sep 14, 2009 | Locks & Locksmithing
I have a safewell electronic safe and no keys and lost code ex2007127402 can i have a code to over ride and open it
hi : about the stockwell safe ex200----- 2535-EA
if the safe still has charged batteries you can deactivate any sceurity code by access through a small hole on the rear of the safe, if you can get to the rear area of the safe.. You need a long screwdriver to reach to the inside of the front of the door . Their is a reset button on the inside of the door in the lower right corner area( "B" button) on the end - not on the flat face surface of the door but on the vertical face( hing plate). You'll have to feel around and push the screwdriver sideways to push the button in.it will beep . YAHOO- YUH DID IT !!!. Then you can reset your own code.if you need further instructions call me . icq. 33819110 or echarron1@cogeco.ca
Jul 26, 2009 | Locks & Locksmithing
Locks & Locksmithing Logo
24 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
