Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
GFI Trips when pluged in.
Got frig from parents. Add on ice maker was removed, and put in thier new frig. Now this one trips the GFI when pluged in. I looked loose or frayed wires but found none. When I unplug what I belive is the freezer thermostat; a large wire loop going under the coils, the GFI does not trip??? The same thing happens using other outlets so its not the GFI
    President:
  • 1,136 Answers
Hi, Are you unplugging the big black hard wire that goes under the evaporator coil in the freezer. If so, that is the defrost heater and it has gone bad. Please let me know if I can explain anything further.
Thanks
Vic
Posted on May 20, 2009
Refrig. sometimes trips GFI, sometimes not. Unplugged plug shows 5 ohms between power contacts. What's up?
Have you checked the GFI with some other appliance? Like a mixer. Sometimes the GFI are overly sensitive.
Jul 14, 2015 | Kenmore 18.2 cu. ft. Top Freezer...
Frigidaire trips gfi when ice maker begins filling with water
It's recommended not to plug refrigerators into gfi's due to regulated amp draws you'll find that if you use an extension cord and plug it into a standard outlet that issue will go away
May 08, 2014 | Frigidaire GLRS264ZA Side by Side...
Coffee maker trips gfi
Try it in a different outlet (one that is not a GFI). It could be the GFI is bad
Jan 28, 2013 | Solis Master 5000 Espresso Machine
Seacoast magic plus keeps tripping gfi breaker
try in different GFI outlet, if it trips the new one, the coffee maker is dangerous and you should return/replace it, it has a short.
if it doesn't, replace the GFI outlet, it is old.
Apr 16, 2012 | Philips Coffee Makers & Espresso Machines
When i plug it in it trips my gfi and it is not on
This can be caused by one of two things. (1) The GFI plug has a problem: it could be broken behind the face plate, or some of the wires in the box are so close that when you push a plug into the outlet, they touch and trip the GFI. (2) The other source is due to a defect in the appliance between the cord and the power switch. That is why the GFI faults even before it the coffee maker is turned on.
Have the outlet checked thoroughly and make any needed adjustments / repair /replacement and reconnect the coffee maker again. If it trips, the coffee maker will need to be serviced. DO NOT use the coffee maker in another non-GFI outlet until it has been checked out. The chances of electrical shock or burns is significant until the problem is found and corrected.
Oct 02, 2009 | Bunn Coffee Makers & Espresso Machines
My frig will be working fine then it trips the GFI outlet. you reset the out and it will trip it again a few minutes later.
Why do you have your fridge plugged into a GFI outlet? It is not necessary if the outlet is hidden by the fridge. A GFI is only used where an outlet is within 6 feet of water and is out in the open. I would replace it with a new regular outlet.
Sep 14, 2009 | Refrigerators
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Jun 10, 2009 | U-Line Uline Origins Series...
Bunn coffee maker triggers GFI
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
Mar 31, 2009 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Aug 30, 2008 | Keurig B60 Coffee Maker
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
147 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
