Question about IBM ThinkPad T30 2366 Notebook
IBM T30 Start-up HD options
I have an IBM T30 with a second HDD in the ultrabay.
On start-up, F12 gives the boot options.
I can see Hard Disc as an option with +Hard Disc, but I cannot find the option to expand to select the second HD to boot from.
Only the HD in the main part will boot, unless I disable the primary in the setup.
When the primary boots you can see the secondary in my computer ok.
Both HD have windows xp.
If I phisically swap the locations, same thing but 2nd drive now boots in the main bay.
How do I choose????
  • IBM Master
  • 32,281 Answers
Why do you what to boot up from the 2nd hard drive?
If you want to boot up with a different operating system from a 2nd drive, I suggest you set up a dual boot system with the other operating system on the 2nd drive.
When you boot up you will be given a menu and you can choose which operating system you want. There is a time delay and if you don't choose a system it will default to the first operating system on the list.
Posted on May 21, 2009
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
Jun 29, 2011 | HP Compaq Business Notebook nx6310 -...
How can i unlock a ibm think pad? when you turn it on it only gives you 2 choices.It says f1 to set up bios utility or f12 to connect with another devise.
try the f12 key and then when boot option opens click on boot from hard drive then save and exit . then you should be good .
Jul 03, 2010 | IBM ThinkPad T30 2366 Notebook
I HAVE LAPTOP IBM THINKPAD T30 AND I WANT TO CONNECT HARD DISK 80GB OR MORE
  • Supported HDD thickness:
    • 12.5 mm for systems without the touch pad
    • 9.5mm for systems with the touch pad
  • Standard 20GB, 40GB, 60GB HDD sizes.
    Note:
    • The 60GB HDD orderable as marketing option part number 08K9688 has a height of 12.5mm and will not fit in the HDD slot of the systems with the touch pad installed. For these systems, it is only supported via the ThinkPad 2nd HDD Adapter for the Ultrabay 2000.
    • The 60GB HDD orderable as replacement service part number 08K9833 is 9.5mm.
  • Supports one additional HDD which can be used concurrently to offer expanded storage utilizing the Ultrabay 2000
  • S.M.A.R.T technology to issue an alert if a hardware failure is pending
  • ATA Bus Interface
  • 4200 or 5400 rpm
  • Although you can upgrade the HDD, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay 2000 HDD adapter is designed to provide this flexibility with a second HDD in the Ultrabay 2000 IBM says. I say if the OS recognises it and so does the BIOS, you're good. good luck, hope this helps.-jmattes p.s. I found this info on: http://www-307.ibm.com/pc/support/site.wss/MIGR-42218.html
Oct 17, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm t30 laptop has no video at start up
Try doing a hard reboot.
Unplug AC and remove battery.
Press and hold POWER for 30 seconds.
Plug in AC.
Turn on.
Upon bootup insert battery.
If this does not work I regret to say the graphics card is busted.
Apr 26, 2009 | IBM Thinkpad T30 Notebook
T30 motherboard problem
press f8 on boot up. select safe mode
Go start>run
type msconfig
hide all micosoft items in services and deselect the remoaining
Also deselect any "dghdfg" looking items from startup
Reboot
Install CCleaner & run
Dec 12, 2008 | IBM ThinkPad T30 2366 Notebook
T30 boots but stop , in windows inst.
I have a ibm 2373 that will only start up and show the ibm and windows xp logo briefly,then the screen goes blank,but i can hear the fan running.
Oct 01, 2008 | IBM ThinkPad T30 2366 Notebook
T30 still won't boot after fan replacement
One of your memory slots might be bad as I'm assuming you tried both memory chips in the known working slot.
I found setting the boot up sequence in BIOS is better than using F12.
Set your BIOS to boot the CDROM first. I suspect the hard drive has failed or has a problem. Do you have a floppy boot disk? Lenovo has PCDoctor bootable diagnostics on their website. You may have inadvertently bent a pin inserting the hard drive. Your CMOS battery could be dead but since that was untouched I would be surprised.
Sep 08, 2008 | IBM ThinkPad T30 2366 Notebook
2nd hdd
both hard drives will need to be jumpered to a master and a slave or both have to be jumpered to cable select. normally the jumper setting are either on the label of the drives or are marked on the bottom of the drives near the jumper drives. if the setting are not shown find the drive type, model and capacity then do a google search for the drive "select the factory manufacture link" and search their site for the jumper setting of the type drive you have.
BPCS
Dec 05, 2007 | IBM ThinkPad T21 Notebook
Ibm t30
The T30 comes with ‘One, integrated, easy-loading modular Ultrabay(TM) 2000 Plus.’
You should be able to buy a DVDR Ultrabay™ 2000 Plus drive that will replace the floppy drive.
For example: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-46337
Dec 03, 2007 | IBM ThinkPad T30 2366 Notebook
2nd hdd
this is os problem
reinstll or repair os
or
harddisk problm
Nov 06, 2007 | IBM ThinkPad A31 Notebook
IBM ThinkPad T30 2366 Notebook Logo
204 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
