Question about Olevia LT37HVS 37 in. LCD HDTV
ZzVzzVzzV on my screen
Having problem with aspect and closed caption fuctions. CC turns off set, aspect freezes pictur then turns off set. I get zzVzzVzzV on my screen when I use the volume control.
  • 70 Answers
Sounds like a bad system board.  Start with Olevia for warranty status, and if it's not covered, check for part numbers on the boards for purchase/repair.
Posted on Oct 19, 2007
How can I turn off CC on my SONY 52XBR. I used the Remote control settings and selected off on the cc display, but the cc never turns off. I also used the menu button on the side of the T.V to select
If Closed Captioning is being displayed even though the CC option in the TV menu is set to Off , then it is being produced by another device, such as a cable or satellite set-top box. To remove the Closed Captioning from the TV screen, it must be disabled on the device that is decoding the Closed Captioned signal.
NOTE: Some set-top boxes may automatically display Closed Captioning on the TV screen when the set-top box sound is muted. If this is the case, turn off the Mute function of the set-top box
Oct 31, 2014 | Sony Tv Xbr Bravia Kdl-52xbr5 52 Lcd Tv...
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
Tip
Black Box on my television.
I have heard complaints from some of my customers, “There is a black box on my television, but I can still see the picture around the edges”. This happens to all of us and is a common symptom and can be fixed very easily. If you have a black box in the picture, on the older sets they would be perfectly centered on the screen, but, on some of the newer sets the black box can be in different places and can be different sizes on different sets.
Most likely the Text mode is on in the Closed Caption menu.
The way you can test if it is in Closed Caption Text mode, when you change the channels, the black box will not appear right away but it will take some time to show back up. This is a very good indication that the Closed Caption “Text” mode is turned on for your television. It just needs to be turned off.
To turn off the closed caption go into your menu and turn off closed caption (CC). This will vary from manufacture to manufacture; it should be in the options menu.
I have seen on some sets like Mitsubishi puts it under the Video adjustments button. So you may have to look around for it.
You may even have a CC button on your remote, which will make it much easier. Just press the CC button until the display indicates that CC it is off.
I hope that this tip helps you and that you enjoy your televisions for years to come.
Thanks for using FixYa
asnowman
on Jan 30, 2010 | Televison & Video
LG 42LS3400 CC option is greyed out and I cannot turn off close captions! Help!
try to go to menu then enter close caption CC option then turn it OFF
Jun 05, 2012 | Televison & Video
Can't turn closed caption off.
Go in ur tv menu go" Picture" go down to reset, press it the tv will back to factory setting.If the Captioning still there.Than ur Tuner Main signal board have problems.
Apr 04, 2010 | Olevia 237T 37 in. LCD TV
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
reports.
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
Big black screen in picture
You have the CC (closed captioning) turned on and it is set to text mode. Look for a button on your remote labeled "CC" or go into your TV menu and make sure the captioning selection is set to "off".
Sep 19, 2007 | Televison & Video
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Olevia LT37HVS 37 in. LCD HDTV Logo
73 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
