Question about Maytag MED6600TQ Dryer
Maytag med6600tq dryer will not start and shows an f1 code
3 Suggested Answers
  • 3074 Answers
SOURCE: My bravo steam dryer is
this is a control board issue, you may be able to clear the fault using these steps:
1) Unplug or turn the circuit breaker off for 30 seconds.
2) Plug the dryer back in or turn the breaker back on.
3) Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
4) Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
If it will not clear then you will need to replace the control board, Good Luck Tim
Posted on Mar 05, 2011
richroth
  • 9472 Answers
SOURCE: maytag dryer model mde5500ayw showing a 8.8 errow code an won't comr on
It means your main control board has malfunctioned and will need to be replaced. Here is the board to order.
Posted on Dec 03, 2012
Maytag Dryer MED6600TQ0 F1 code
please follow this steps , use the multimer and fix it. Merry Christmas
The F1 code is a thermister error code. You need to use a meter and check the thermister, it is located on the blower housing. Just remove the lower panel to get at it. Unplug it and it should read around 10K ohms at room temp. If it is very low or does not read at all it needs to be replaced. If it is good you need to check the wiring from the thermister to the board to see if it is good. If it is and still displays the F1 code you need to replace the control board. That board is located on the left hand side of the unit when you have the top off you can see it on the left hand wall. Here is a link to the parts for your unit.
Dec 18, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer wont start
-Check door switch.
Good luck
Mai
Nov 16, 2013 | Maytag MED6600TQ Dryer
Maytag dryer epic z flashes error F1
bad thermister part number 8577274 and it's around 30 dollars.go here and see the part
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MED9700SQ0/3048/0151200/W0802068/00003?blt=06&prst=&shdMod= number 42 on the diagram.hope this helps.also there should be a tech sheet with info and error codes on it.don't loose this paper in case you ever have to call someone in to service it
Jan 06, 2013 | Maytag MED9700S Electric Dryer
Dryer not shutting off
Does it not shut down by the timer?
Nov 11, 2012 | Maytag MED6600TQ Dryer
My bravo steam dryer is showing an F1 code, and I can't get it to start
Mar 05, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
Maytag MED6600TQ Dryer Logo
97 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
