Question about Panasonic Televison & Video
Ds830ny what are the IR codes for this device?
Logitech harmony hub ir blaster will not turn on projector
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 23, 2016 | Logitech Harmony Smart Control Universal...
Eror code e00732-0010
check the cable that connects the scanner to the copier body
it sometimes gets broken you can wiggle it and reboot the device
thats the only thing that goes bad for this code
Oct 29, 2012 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Will a 3.4 IR remote work in place of a 3.1 IR remote
It should work, provided has setup codes for your device. Check whether there is setup codes for the device do you want to programme with it. You can get this information from the code list of the remote control; you have purchased. If there is no code found, you can just search for a code.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 30, 2012 | DISH Network IR Remote Control
Control Curtis dvd6041 with dish-network remote 5.0 IR
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for our more popular models of remotes and the instructions for addressing the remote to your DVD player. I hope you find this information useful but if it does not work or you have any further questions please let me know I would be happy to help further.
Remote model #'s Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 1594, 1605, 1607, 1675, 1554, 1592, 1677.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 1594, 1684, 1554, 1605, 1607, 1592, 1678.
4.0 and 4.4 IR/UHF remotes - codes 1684, 1554, 1594, 1605, 1607, 1592.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 1592, 1594, 1605, 1607, 1554, 1683, 1675.
20.0 IR and 21.0 IR/UHF remotes - codes 1585, 1554, 1592, 1594, 1685.
Instructions for addressing the remote to the DVD player
  1. Press and hold the AUX mode button until all mode button back lights come on, then release.
  2. Use the number buttons to enter the device code corresponding to the equipment.
    Note: The light will blink off after each digit is entered and then return to a steady light.
  3. Press the POUND (#) button.
    If the code entered is valid for the remote, the mode light flashes three times.
Oct 10, 2011 | Curtis DVD6041 System
I need a code for Symphonic DVD that works with Dish Network
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post recently and wanted to see if I could help. For each of our different models of remotes we have a few different codes that could work with a Symphonic DVD player. I will list here for you the best codes for our more popular models of remotes and also the instructions for programming the remote to your DVD player. I hope this information helps you and if you have any further questions or concerns feel free to ask! :)
Remote model # Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 1688, 1683, 1588, 1594.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 1632, 1522, 1300, 1588, 1594 1624, 1692.
4.0 and 4.4 IR/UHF remotes - codes 1632, 1569, 1733, 1569, 1846.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 1733, 1632, 1694, 1588, 1594, 1756.
20.0 IR and 21.0 IR/UHF remotes - codes 1658, 1588, 1804, 1531, 1617, 1619.
Aug 20, 2011 | RCA 3-Device Universal Remote with...
I am attempting to program my remote to an aiwa stereo but i do not have a code and I don't remember how do that. HELP!!
Hey there, my name is Cheri Torres and I am with DISH Network customer service. I came across your question and I would be happy to help you with this issue. :) We have a few different codes for all of our different IR remotes. I will give you all of the codes that work the best, for the most common IR remotes that we have. You will be able to see which model remote you have by looking on the back of the remote at the top. The model number usually consists of two digits with a decimal point. For the 3.0, 3.1,3.2, and 3.4 IR remotes the most common codes for an Aiwa Stereo are 636, 641, 656, 687, and 718. For the 5.0, 5.2, 5.3, and 5.4 IR remotes the most common codes are 718, 641, and 720. Here are the instructions for addressing your remote to your stereo. I hope you find these codes and instructions useful. If you have any other questions feel free to post back here or email me at Cheri.Torres@Dishnetwork.com.
  1. Press and hold the desired Mode button until all mode button back lights come on, then release.
  2. Use the number buttons to enter the device code corresponding to the equipment. AUX Mode: Before entering the device code:
    • Press 0 for a TV
    • Press 1 for a VCR/DVD
    • Press 2 for any other device.
  3. Press the pound (#) button Note: The light will blink off after each digit is entered and then return to a steady light.
  4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Dec 29, 2010 | DISH Network IR Remote Control
Looking for vizio tv remote codes for denon 1802
I don't think you'll find any codes as the Vizio remote uses a newer IR coding than the Denon.
However, you can replace both remotes with a Logitech Harmony Universal Remote!
The Harmony remotes work on several different IR coding schemes with many different types of devices.
If 1 remote is what you're after, the Harmony remotes are the best!
Mine has saved several devices for me because I could just download the latest IR codes from their website AND I can teach it the codes if I can't download them but still have the original remote for the device.
This is definitely the way to go, IMHO.
Hope this answers your question.
Dec 04, 2010 | Denon AVR-1802 Receiver
Trying to find code for ir emmiter on archos 605wifi
well uh i don't know exactly what u want but u can use the psp as a remote it must be the fat (1000 series) and have custom firmware and irshell it can "learn" the ir code
Jan 16, 2009 | Archos 605 WiFi Digital Media Player
IR Receiver
Are you serious?
In case you are serious, IR=infrared.
When you point your TVs remote control toward the TV and press a button, it is the IR receiver on the TV which receives the IR signal which is transmitted from the IR LED (Light Emitting Diode), which is the small bulb like part, on the front end of your remote control.
Any device using a IR remote control, must have an IR receiver to gather the siganl being transmitted. The IR siganl is a coded message of instructions for the device.
Dec 08, 2007 | Jazz DV-179 Digital Camera
Televison & Video Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
