Question about Neff K4316X0 1GB Compact Refrigerator
How to fix door to integrated fridge - Neff K4316X0 1GB Compact Refrigerator
Door of intergated fridge wont shut
This is a really open question but I assume you have checked for items inside causing obstruction.
That done now look at the hinges, it is possible one or either of them have become dislodged possibly from the bolts coming loose or from being shut with a something sticking out inside.
Another possibility is the magnetic strip around the door has come off, its an easy fix just push the little poppers back in the holes on the door.
More info would help answer the question.
Mar 10, 2015 | Refrigerators
How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Oct 06, 2014 | Refrigerators
Schreiber app6302 integrated fridge
Sounds like the door has twisted
a quick fix is to place an object like a soccer ball
on the floor in front of the fridge while the door is still open
Pushing the top of the door slowly try closing it against the ball to twist the door straight
this is a trial and error aproach that does need a bit of force however it does often work and saves the alternative which is dismantling the entire door
Apr 14, 2014 | Refrigerators
HI! I broke the handle on the door at the freezer. Can that be fixed? If not where can I buy a new door? The model of my fridge is: Kuppersbusch Integrated Fridge- Freezer Modell: IKE 318-6. Thank...
We were able to purchase a replacement handle for our freezer from RepairClinic.com . You'll need the model #, Serial #, and date of manufacture.
Jan 18, 2011 | Refrigerators
Door on my integrated Bosch fridge keeps opening
Seals rarely fail most likely needs hinges replaced,parts quite cheap
Jun 16, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Neff K4316X0 1GB Compact Refrigerator Logo
26 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
