Question about Mtd Gold 31AH65LG704 357CC OHV 4 Cycle 28" Snow Thrower
Engine is surging and then stalls
Engine starts runs strong for a few minutes then surges and stalls
1998 MAZDA PROTEGE STARTS-THEN SURGES AND DIES OUT
Have the charging system tested, sounds like you may have Alternator issues.
Jan 18, 2017 | Mazda Cars & Trucks
Engine surging 179cc craftsman snow thrower
sounds like the carb will need removing and having it ultrasonic cleaned
Dec 16, 2011 | Mtd Garden
My car surges some times
Follow this procedure for these kinds of problems.
Here is the most common cause of surges and stalls and low idle, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Jan 10, 2009 | 1991 Ford Escort
01 Focus 2.0 split port engine. Service engine light on!
uplug air metering sensor car should run almost normal but will set check eng, light
Nov 29, 2008 | 2001 Ford Focus
Honda accord 1996 v6 2.7 liter,rpm gage jump up and down
Here is the most common cause of surges and stalls, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Nov 28, 2008 | 1996 Honda Accord
My car surges after running for 10 minutes when I put it in parking or drive can you tell what is wrong .
Nov 05, 2008 | 1991 Ford Escort
Car petrol engine revolution surges.
Oct 28, 2008 | 2004 Isuzu Rodeo
2000 focus engine surgeing on tickover
Here is what you need to do, a cleaning of the intake throttle blade and the idle speed control air-bypass valve, they get full of gunk over the miles and cause idle issues (stalls) like yours,
Oct 25, 2008 | 2000 Ford Focus
Mtd Gold 31AH65LG704 357CC OHV 4 Cycle 28" Snow Thrower Logo
43 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
