Question about Hotpoint Ovens
How to change regulator on hotpoint ew 85 - Hotpoint Ovens
How do you replace main oven temperature indication light for hotpoint double oven cooker model ew 74
In doing a general google with the brand/model, there are many things that come up about issues. You need to contact http://www.geappliances.com/service_and_support/contact/form_email.htm. They state their product is backed by GE. Many places sell this, but look for one with GE products. You might have an appliance store close by with that information.
Mar 06, 2014 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
I have a hotpoint ew 52 cooker and the grill does not work. it is part of the top oven.
You need to establish if it is the element that has failed or the control switch, usually it is the element(s)
Aug 07, 2010 | Hotpoint Ovens
Hob on my hotpoint oven trips my RCD
It is either a faulty ring, or the regulator that controls it is faulty.
You really need a meter to test the ring with to be certain which part is faulty.
Hope this helps.
Feb 21, 2010 | Ovens
Timer clock is not illuminated and oven will not work
This does have an internal fuse and there are probably 2 or 3 of them. They should be located right behind the timer or thermostat.
Feb 03, 2009 | Blodgett Ovens
Instruction manual required
I have checked the Hotpoint website user manuals, and your model EW 84 is listed and available for download, so don't know why you could not find it.
If you still can't find it let me know.
Plz rate my solution.
Thanks.
Dec 27, 2008 | Hotpoint Ovens
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Thanks.
Dec 26, 2008 | Ovens
My Hotpoint UY46 main oven overheats
cant't think it is anything other than the thermostat - a routine fault
Mar 11, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
27 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
