Question about Simplicity Garden
How to adjust valves on Kohler engine
Not sure how to adjust valves on hdro 18 v- twin engine
5 Suggested Answers
boscia
  • 163 Answers
SOURCE: How to adjust the idle on my lawn tractor
there should be one screw at the top of the carb, that is the fuel intake adjust screw. turn clockwise all the way down without force. start the mower and slowly turn clockwise until rpm sound right
Posted on Nov 30, 2008
backwoodsctr
  • 169 Answers
SOURCE: Kohler engine carburetor adjustment on John Deere Model 112
When u adj a kohler carb you adj fuel not air. Always adj the high speed then low speed. Then adj the curb idle. 1.5 turns out is a good starting point. Then tweak it after its warmed up. Hope this helps
Posted on Nov 20, 2009
SOURCE: i have a craftsman kohler magum 18 hp twin
I had the same problem with my tractor.same tractor and everything.all u have to do is you know the wires that hook up to your seat?them 2 wires cant be touching eachother.if them 2 wires that hook to your seat r touching eachother,it will stall out when u let out the clutch.
Posted on Apr 19, 2012
ciliacarmelo
SOURCE: Craftsman 42 " mower w/Kohler 18 horse engine clicks, but will not turn over.
my westwood tractor 1600hp will not charge the battery
Posted on Apr 17, 2013
25hp kohler hot start problem. Replaced fuel filter, plugs and cleaned air filter - same problem. it won'd restart when hot.
3 possibles come to mind
fuel vaporization in the line to the carby or in the carby bowl (check float level adjustment)
valves are being held open when hot--- valve stem lengths increase reducing tappet clearance___adjust valves when hot
check coil/ ignition module for failure when hot as they can open circuit ./ short circuit when internal components fail from heat
Sep 27, 2016 | Kohler Command V-Twin Horizontal Engine...
How to adjustvalves on kohler22 on craftsman
Gary, they may be hydraulic and not require adjustment, check the attached links, they will help determine and show how to.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://outdoorpowerinfo.com/engine_specs/kohler_valve_clearances.asp
How to Adjust the Valves or Valve Lash on Kohler Courage XT Lawn Mower...
Work on the Cub Cadet i1046 Kohler twin setting the valves
Owners Service Manuals
Apr 14, 2016 | Cars & Trucks
Kohler command 18 not getting gas to carb and fuel pump is working fine
Tankairiation, tankfilter ,tapfilter pourous hose floatchamber ,nozzle , gaskets
Mar 19, 2016 | Kohler 18 Hp OHV V-Twin Command Engine
Kohler V-Twin (624 cc) RPM on the engine does not stay stable , It will raise and lower the RPM in any Throttle Range. Could the Governor be going bad???
Try a static governor adjustment first as it simply be out adjustment.
Static Adjustment Procedure
Make this adjustment whenever governor arm is
loosened or removed from cross shaft. Adjust as follows:
1. Make sure throttle linkage is connected to governor
arm and throttle lever on carburetor.
2. Loosen nut holding governor lever to cross shaft.
3. Move governor lever toward carburetor as far as it
will go (wide open throttle) and hold in this position.
4. Insert a long thin rod or tool into hole on cross shaft
and rotate shaft clockwise (viewed from end) as far
as it will turn, then torque nut to 6.8 N·m (60 in. lb.).
Aug 23, 2014 | Garden
18 hp kohler engine starts but doesn't keep running!!!!
You put in a question about your ride on. What is it you need?
Aug 15, 2014 | Kohler 18 Hp OHV V-Twin Command Engine
What would be the cause of a Kohler 25hp twin, backfiring through carb from one cylinder
now the kohler v-twin does have a bit of a problem with camshafts in this size range , your gonna need to remove valve cover on head side that you suspect is bad , verify that valves move in order (one at a time) as you turn over by hand with spark plugs removed (both sides)
Jun 16, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Bad plug, ignition wire, valve clearance, or valve damage, vacuum leak at manifold. Timing cam off / damaged
Craftsman zt 7000 18 kohler comand vualve settings
the valves are not adjustable on that engine
Apr 28, 2012 | Craftsman Garden
Garden Logo
20 people viewed this question
Top Simplicity Garden Experts
Dennis Key
Dennis Key
dannydoesita
ray gallant
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
