Question about Compaq Presario X1000 Notebook
Cant turn on my lapton another problem
My laptop is completely dead. the yellow light indicating that the AC adapter is plugged in will not come on. I have tried different outlets and made sure that the battery is not lose and inserted correctly and fully. The battery is completely drained and no lights are on indicating its life. Any ideas?
If I cant turn it on any ideas on how I can save data out of the hard drive?
  • mahriah May 27, 2009
    I checked the AC adapter with a voltage tester and it is working correctly and fully. Any other ideas?
  • DWDpcRepair May 11, 2010
    sounds like your ac adapter may be dead. you can test it with a voltage tester to see if its doing its job. there should be a sticker on the av adapter with the voltage specs.
    Sniper:
  • 85 Answers
You can just pull the hard drive and buy an external enclosure. its a cradle for the hard drive that connects to another pc so you can extract whatever you need from the hard drive.
Posted on May 20, 2009
Computer doesn't turn on at all.
You'll need to replace the coin cell battery on the motherboard to get it to boot again.
May 16, 2017 | Power Computers & Internet
I have a toshiba laptop about 2 years old. I didn't use it for a few days and now it won't turn on at all.
was it plugged in when you tried to turn it on?
if not, try charging it for a couple of hours. the battery must be completely empty
other than that I might need more details
Aug 07, 2011 | Toshiba Computers & Internet
Cannot turn on my laptop only the start button light turns on but no screen display and a few noises help
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 15, 2011 | Acer Aspire 5500 5570-2609 Laptop
I was just kind of chilling on my laptop most of the day. And it kept like running outta battery like it normally kinda does every now and again. I kept it plugged in most of the day but it wouldn't...
Dec 28, 2010 | Computers & Internet
Toughbook will not start, we have it plugged into the wall and when we switch it on the battery light turns red and nothing else happens? Thanks, Brad M.
> battery light turns RED
For Panasonic computers, that indicates that the battery is almost completely discharged (it's YELLOW while charging, and GREEN while fully-charged).
So, my guess is that your AC adapter has failed,
and that your battery needs recharging.
Or, the socket where the AC adapter connects into your computer is damaged, such that no power from the AC adapter is reaching the computer.
Take a "MultiMeter" and check the voltage & amperage output-level from your AC charger. If "zero", go onto eBay and search on the part-number, to find a compatible replacement part.
Oct 11, 2010 | Panasonic Toughbook 28 Notebook
I turned my lapton on and it will not boot up. What happend and how can I fix it
If you have to ask "how", then it's time to take it to a qualified technician, for professional trouble-shooting.
It could be a dead battery, or a dead AC adapter, or a dead motherboard, or a dead 'C:' drive.
Apr 23, 2010 | Dell Latitude D510 Notebook
I have a Toshiba Satellite laptop and it's about 10 years old. That's why I need to plug in to my ac adapter in order to turn it on. But now, even when I have the ac adapter plugged with my laptop, the...
Nothing! Yellow light indicates a depleated battery. My guess is the battery is shot! The laptop is still working and the yellow flashing light has no affect on the usability. Buy a battery if you want it to stop! They are real expensive and may not be worth doing. Keep using the laptop as is.
Dec 04, 2009 | Toshiba Satellite Laptop with Intel...
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Travelmate 2300 won't power on
The problem could be your bezel.  Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open)  once removed, press the button on the motherboard under where the power button is.  If the unit still does not power up, then your motherboard is bad and needs to be replaced.  If it does power up, you need to replace the bezel.
Oct 18, 2007 | Acer TravelMate 2300 Notebook
Compaq Presario X1000 Notebook Logo
126 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
