Question about Fuller Brush Vacuums
Raise brush on Fuller Brush FBP 12PW-2 - Fuller Brush Vacuums
guide2u
  • 461 Answers
SOURCE: Dyson DC14 Bar brush and belt replacement.
Try the op manual http://www.dyson.com/customercare/manuals/us/dc14_opmanual_usa.pdf
Posted on Aug 30, 2007
  • 3 Answers
SOURCE: brush roller not moving
This problem has unfortunately plagued many owners of this vacuum including myself. I'm not an expert on vacuums, but through some experimentation I found a workable solution. You can first try a new belt, but that will unlikely solve the problem. For some reason the drive shaft becomes too slick for the belt and so the shaft will spin but it won't catch the belt. I wrapped a piece of electrical tape around the shaft for some added friction, and voila, everything started working again. Eventually, the electrical tape shredded a bit and fell off, but it left enough residue on the shaft to retain friction. I know this sounds like a real hack job, but if you've given up hope on everything else, or you can't return the vacuum, it's worth a shot.
Posted on Sep 23, 2008
ronald_kate_
  • 111 Answers
SOURCE: the brush does not rotate
Hello, see if you can turn the roler by hand ( MAKE SURE VACCUME is OFF), if you cant turn it try checking that there isnt something caught up on either side of the roler. Sometimes things can get caught on the spindel at either side and it winds up fairly tightly. If this isnt the problem then eithr a drive belt has worn or broken, or a driver cog could be worn. If this is the case then you will need a technician to have a look for you. I hope this is of some use.
Posted on Nov 05, 2009
  • 9 Answers
SOURCE: MY WIFE BOUGHT THIS FOR ME FOR FATHERS DAY GIFT
This unit uses a turbine assy to turn the brushes. The brushes could have something jamming them. Remove the brush unit, it is held on 2 spring hooks 1 on each side. The brush unit is driven thru a 1/4" square post, only one brush is driven and it drives the next then it drives the next etc. If something is jammed in these gears it will stop the entire brush assy. The turbine assy could be bad, but I would check the brush assy first.
Posted on Nov 15, 2009
  • 8 Answers
SOURCE: Roller brush will not rotate. Brush motor and
More than likely there is gunk underneath the endcaps. In the small airdriven attachment those end caps come off. It's likely true of the beater brush underneath too.
Posted on Jul 26, 2010
My Fuller FB-DCC wand segments won't grip to the floor attachments or the small brush. The crevice and upholstery tools fit snugly, but the other pieces won't hold to the wand.
Hello, Kaye -
I suggest you contact the Fuller Brush company directly about your vacuum cleaner.
This is the link to the company's Contact Us web page:
http://fullerbrushvacuums.com/support/contact-us
The toll free phone number is at the bottom of that page. You will need to wait until 2 Jan 2018 to call, however.
Dec 31, 2017 | Vacuums
Need bags for fuller fb75t
We have bags for that vacuum here.
GoodVac.com
www.goodvac.com
1-800-775-6586
Apr 21, 2014 | Fuller Brush FB75T Upright Vacuum
My Fuller Brush FB90T Bagged Upright Vacuum shutdown during vacuuming. I allowed it to cool off for a 24 hours but it will now no longer restart. Is there a reset function?
Check if there is debri at the bottom behind the roller where the dust gets sucked in. There is a reset button in this area. Press it with a needle or pen tip. Hold it for about 5 seconds.
There is a overburn protection if their is obstruction in the hose due to which the vacuum shuts down. Resetting it will fix this issue
May 23, 2012 | Fuller Brush FB90T Bagged Upright Vacuum
Fuller Brush FB90 Bagged Upright Vacuum not starting
Try pushing the reset button located at the bottom on the back of the machine. If the reset button has tripped it usually indicates a clog or restriction somewhere caused the motor to overheat.
May 23, 2012 | Fuller Brush FB90 Bagged Upright Vacuum
The vacuum is not suctioning. Fuller FB 90T
First replace the belt if it's over 6 months old. Stretch belts lose elasticity. It may still turn the brush roll but when vacuuming the carpet it may be slipping and not turning fast enough. Make sure bags and filters are good.
Sep 07, 2011 | Fuller Brush FB90T Bagged Upright Vacuum
My fuller brush household canister vacuum doesn't have as much suction as usual. I've changed the bag and cleaned filter. Any other ideas?
. Test the suction without the pipes to confirm that the motor is sucking strongly, then check that there are no blockages in the pipes and fittings.
Jan 29, 2011 | Fuller Brush FBPTCAN Bagged Canister...
I have a cannister vacume, Fuller Brush red model # FB-DCC when I turn it on it will shut itself off in about 30 seconds this will happen several times then it will not turn on. I do not have the owners...
First, the word is "VACUUM." Second, it's obvoius that your motor is overheating. When's the last time you CLEANED THE FILTERS, per the operating instructions?
Nov 07, 2010 | Fuller Brush Vacuums
Fuller upright vacuum model FBPT-2
Be sure that you have the bag holder frame in place correctly.
The door will not close and latch without it.
Oct 02, 2008 | Fuller Brush FBPTCAN Bagged Canister...
Vacuums Logo
20 people viewed this question
Top Fuller Brush Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Fuller Brush Vacuum Expert? Answer questions, earn points and help others
