Question about Maytag Washing Machines
Maytag maxima washer error codes f01 e02 - Maytag Washing Machines
2 Suggested Answers
SOURCE: Maytag Maxima Front Load Washer. F01 / E02 error
Tip the machine up & look inside up high, you
should find a bag with the diagnostic service
manual & it has the codes
Posted on Sep 05, 2013
Maytag maxima ecoconserve washer My washer will not operate. The lights come on as if it will I hear a few noises, but water will not enter it and it does not operate. Error Codes are E02 and F06
you have a communication error from the UI (user interface) to the CCU (Central Control UNIT). It could be the wiring or the control itself
Feb 06, 2016 | Washing Machines
MHW6000XW LIST OF ERROR CODES AND WHAT THEY MEAN
F20 water only problem insufficient water supply open both hot and cold unclog hoses
F21 Drain problem clogged,frozen kinked
SUD excess sud using non he detergent or to much detergent
F22 front door lock door not closed properly
For these select poepwer/cancel twice to cancel cycle
Other f codes select power/cancel twice select drain& spin if youhave excess water
Jul 10, 2015 | Maytag MHW6000XW - MaximaTM...
My may tag washer has codes F06 & E02 , what does this mean?
I beleive e02 is something to do with ur drain pump set up clogged or damaged water pump and hoses
Jun 15, 2015 | Maytag MHW6000XG Maxima High-Efficiency...
Error code E02 and F01.
Replace the motor control board. The machine cannot tell the speed any longer. These boards are expensive and even much more time consuming to think you can repair the board. Call your local parts place and ask them if they can have the board tested, if you want to .
Mar 24, 2015 | Maytag MHW6000XW
What are the error code for F09 and E02. for maxima maytag
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
Washer will not run
f06 OR e02 error code means you have an interface communication error. the main control board isn't communicating with the front interface control board. if you pull the washer out and remove the 3 screws coming in from the back of the top panel. the top panel will pull straight back, up, and off. check all the wire connections between the two control board and make sure they are all secure. if everything looks good, then the interface control board may need to be replaced.
f01 e02 means that your motor control board is not reading the tachometer on your motor when it tries to turn the motor. it thinks that the motor is struggling. open the door and turn the basket to make sure it spins freely.
Sep 28, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
Error code F01 E02
For how long did you unplug the power cord? If it was under 5 minutes, unplug it for longer. Check if that clears the error code. If it doesn't, the motor control unit needs to be replaced.
Please double check your model number to get the correct part. Most of the Whirlpool washers have model numbers that start with 3 letters.
I hope this helps.
Dec 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Maxima Front Load Washer. F01 / E02 error codes. Power on, kicks off cycle, locks door, but will not call for water.
Sep 04, 2013 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
