Question about Hisense Televison & Video
Change 720p 1080p - Hisense Televison & Video
  • 4 Answers
SOURCE: How to get 1080p?
in addition many TV service providers are unable to send a true HD signal. the max is 720p or 1080i as refered to above. some sattelite companies are beginning to dabble in it but nothing full swing as of yet.
Posted on Jan 05, 2009
  • 160 Answers
SOURCE: how do I change the resolution from 720p to 1080p
If your Sony TV is designed to display 1080P resolution - you don't need to do anything. It does it automatically synchronizing with appropriate 1080P signal source.
If source does not produce 1080P (because it can't or settings are wrong) TV won't display it.
Regards.
Russ.
Posted on Aug 12, 2010
budmrtn
  • 11361 Answers
SOURCE: how to change my display
The resolution is dictated by the video source, if it is fed with 720p, you will get 720p res, feed it with 1080p will display 1080p, just like your PC monitor which is controlled by your PC video card resolution setting, not at the monitor.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Oct 07, 2010
  • 16 Answers
SOURCE: picture is only in 720p
You can use the TVs original remote or if you use a universal or programmed remote just make sure the remote is on TV.
Then you just have to press menu. In the menu select a setting such as Screen or Display or something to this same idea and it will allow you to select the picture output. It should list all hte possiblities for your TV including the 1080p.
Hope this helps. If it did not answer your question please reply back and I will gladly walk you through the process further.
Please rate me well if this was helpful so others will know to ask me for help. Thanks again and I hope everything works out with your TV.
Posted on May 15, 2011
SD Tech
  • 14553 Answers
SOURCE: I have a Sanyo CE37FD47-B 1080p but every time I
The program may only be available in 720 and as such does not mean anything.
Posted on Jun 12, 2012
How do I change resolution from 720 to 1080
Hi, You don't change it. Your t.v. will play at 1080p if it is a native 1080p t.v. and it is receiving a 1080p signal. If it is receiving a 720p signal. Then it will play at 720p. If your t.v. is native 720p and receives a 1080 signal. It will scale down the signal to 720p.
May 13, 2016 | Televison & Video
How I get a 1080p display. I only get 720p
You need to have a 1080p source. Most TV channels broadcast in 720p. Otherwise, a bluray player hooked up via HDMI will give you 1080p. The TV will switch to the correct resolution automatically.
Feb 18, 2016 | Westinghouse 48 1080p LED HDTV
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
I need to change the resolution to 1080 on a vizio D650i-B2
The resolution for TV's is auto sensed by the content being sent to it.
If you are playing a 720p file, you cannot make it 1080p. 720p vs 1080p Can You Tell The Difference Between HDTV Resolutions
Apr 26, 2015 | Vizio Televison & Video
Shows 720p but should be 1080p seiki se24ft01
This will be ether the zoom button on the remote or If you go onto the menu screen settings
Jan 04, 2014 | Seiki 24" Class 1080p 60Hz LED HDTV...
HI...HOW DO I CHANGE MY TV FROM 720 TO 1080?
U talking about tv show broadcasting in 720p,u wanted to changed it into 1080p.U can't do this,u only get what the tv stations modes,what ever modes they put out only.Put out 720p u get only 720p,if put out 1080p u get 1080p only.
Jun 13, 2011 | Mitsubishi WD-52525 52" Rear Projection...
How to change my display setting from 720p to 1080p
Oct 07, 2010 | LG 32LD550 32 in. LCD HDTV
How do I change the resolution from 720p to 1080p
Regards.
Russ.
Aug 12, 2010 | Sony Televison & Video
I have a Toshiba 40RV525U LCD TV. Wondering how to
if it is with hdmi input call toshiba--free software upgrade
Jul 12, 2010 | Toshiba 40RV525U 40 in. LCD TV
Call of duty 4 1080p
First off, Sony doesn't make Aquos they make Brava. Sharp makes Aquos. Secondly, I am unable to uncheck 720p how do I do  this?
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
77 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
