Question about Motorola Mobility V365 Cellular Phone
All phone numbers stored on phone memory were erased
My Motorola V365 phone somehow deleted (or hid?) all of the phone numbers that I had stored on the phone memory rather than the Sim Card. I took the phone to the phone store and they have no clue.
    Problem Solver:
  • 9 Answers
This happened to my razor a couple of times and no one could help me fix it. As far as I can tell, there is no way to fix it. One thing to do for next time though, is when you key in all of your numbers again, save them to the SIM card. This way if it happens again, which it did with me, you won't have to redo as much.
Posted on May 20, 2009
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
Need help!! please.!
I used to have that phone myself, and it is a good phone. You can't delete the network photos, but you can add you own using a memory card, and transferring the photos to the phones memory first, and then using them as background. if you simply want to store the photos, just keep them on the memory card. Motorola Phone Tools is an excellent multimedia software for this phone, and you can download it free from the internet.
Jul 19, 2009 | Motorola Mobility V365 Cellular Phone
How to delete messages
go to "message center". press menu button then select "cleanup messages"
Jun 20, 2009 | Motorola Mobility V365 Cellular Phone
Phone's pin number locked me out
default PIN number for motorola is 0000.
Apr 02, 2009 | Motorola Mobility V365 Cellular Phone
Reset motorola razor pink manually
all the info i can give you. you cant manually reset it
reset settings
Reset default settings for all options except the
unlock code, security code, and lifetime timer:
settings> phone settings>Reset>Reset All Settings
delete data
Caution:
This option erases all information you
have entered
(including contacts and calendar
entries) and content you have downloaded
(including photos and sounds) stored in your
phone’s memory. After you erase the information,
you can’t recover it.
This option does not delete SIM card information:
s >u Settings > Phone Settings > Reset > Delete All Data
Caution:
have entered
(including photos and sounds) stored on your SIM
card. After you erase the information, you can’t
recover it.
> Delete Memory Cards
Jan 16, 2009 | Motorola Mobility RAZR V3i Cellular Phone
I have a Motorola V365 phone. The phone was dropped several months back and broke a portion of the cover that holds the hinge in place on the flip portion. The phone has continued to work fine. This past...
Your best bet is to take it to your cell phone service provider to see if they can retrieve that information. If you are on Verizon, they offer the backup assistant to retain information like this and to be able to transfer that information onto other replacement phones. The memory in your phone is probably OK and that is where your contact information is located so they should be able to recover that. The small ribbon cable that broke provides power and data to the display and should not affect your stored data. If that cable has a short across it, it may impact your ability to get your data on your own.. Good Luck
Regards,
Rick
Dec 07, 2008 | Motorola Mobility V365 Cellular Phone
I bought a Motorola V365 but received no instruction book. I was able to figure out the sim card installation, but can't figure out how to install the sd card. Help! Donna
you need to look at the phone and see if they is a slot on the phone that reads sdcard or memory card then just open it up adn place the card inside.
Dec 01, 2008 | Motorola Mobility V365 Cellular Phone
Saving text messages from v365
You can save the text messages into the computer using the software from Motorola.
Motorola Phone Tools allow you to transfer all the information between the cellphone and the computer.
You can get it from store.motorola.com
Also remmber that you are not gonna be able to save text messages or contacts information in a memory card.
The memory card allow you to transfer just Multimedia stuff as music pictures or videos.
Good luck
Oct 24, 2008 | Motorola Mobility V365 Cellular Phone
Erasing all phone numbers and user information on A650
FROM THE MANUAL
ERASE MEMORY
Erase memory erases your Phonebook and Voice Dial recordings. This feature is useful if you want to give your phone to a friend or family member.
1. In standby mode, press the left soft key (Menu), then press 9 (Setup), 4 (Security). You're prompted to enter the lock code.
2. Enter the lock code (try the last 4 digits of your phone number unless you set a different one), then press 6 for Erase Memory. A confirmation prompt appears in the display.
3. Use the navigation key to highlight Yes or No, then press OK. A confirmation message appears in the display while your messages are being erased. Your phone then returns to the Security menu.
RESET PHONE
Reset Phone returns all setup options to their factory default.
1. In standby mode, press the left soft key (Menu) then press 9 (Setup), 4 (Security). You're prompted to enter your lock code.
2. Enter the lock code, then press 7 for Reset Phone. A prompt appears in the display asking if you wish to restore default settings (except for the Phonebook and Voice Dial).
Feb 05, 2008 | Samsung SCH-a650
Motorola Mobility V365 Cellular Phone Logo
129 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
