Question about Hitachi P50H401 50 in. Plasma HDTV
Screen black Power on does not display a screen. The power indicator is blue. The HDMI2 and AV1 and AV4 input signal do not make a screen appear. Other inputs act the same. I can use the remote to e.g. go into standby, i.e. power indicator turns red. I can switch from standby to on "Blue power indicator" but no screen from the input appears. When switching between inputs on the remote control there is an occasional "light up", but no TV picture from the input source comes up.
  • Hitachi Master
  • 10,045 Answers
Here's the test to determine which board is faulty. With the TV on, as usual, shine a flashlight on the screen to see if there is a faint picture. If there is, then the ballast board for the backlights is bad. If there is no visible picture, then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on Jun 27, 2017
SOURCE: Hitachi P42H401 - No Picture or Sound. Some Menus work.
find and push the "reset button"
Posted on Sep 02, 2007
SOURCE: Unit will not turn on from standby
I had a similar problem and it was caused by my cable box being in scart 1 as soon as I changed over to scart 2 the problems went away,
Posted on Jul 24, 2008
  • 187 Answers
SOURCE: Can turn on to red light and get blue light, but no picture
The mainboard needs to be replaced
Posted on May 27, 2009
  • 1077 Answers
SOURCE: Powers up but picture doesn't appear.
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Posted on Jul 08, 2009
Rally Guy
  • 3 Answers
I can't help you because after 26 months of ownership mine is doing the same thing (started on 7-12-09). Judging by the number of people with the same complaint I believe Hitachi knows that they have bad boards but refuses to replace them for customers unless they are within warranty. It also explains why the merchant that sold it to me in 2007 stopped offering Hitachi in 2008.
I'm disgusted because I'm anticipating a $300-$500 repair bill simply because Hitachi's design did not provide an external way of resetting it. Impossible to get to the menu to do a reset within 12 seconds before it starts the powering on booting cycle again.
Adding salt to the injury, mine is wall mounted and repair people will only work on it if it is readily accessilble when they walk in the door or if it is brought to the shop. Know what a 55" plasma TV weighs? Too much.
Posted on Jul 13, 2009
Olevia 537-B11. Why is there a blue screen with a "no signal" message?
try main menu look for input should be Air (antenna) ,cable, av1, av2, hdmi1, hdmi2 and perhaps more. do an automatic channel scan if you have an antenna hooked up. will take several minutes scanning
Oct 09, 2015 | Televison & Video
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
I turn on the cable and power button then the TV and poweer on and only balck screen and AV appears in the right hand corner. Can't get my TV to wrok. Yet the one in the living room works
Make sure that the source input is set correctly. You can select the different "source inputs" using your TV remote. For example, if the cables from the cable box going to your TV are going into AV1 port on your TV then you need to select AV1 as the "source input" on your TV settings. This works the same with HDMI1, HDMI2, ect.
Jul 17, 2011 | Televison & Video
My plasma LG TV has a black display box in the top left corner of screen. No words or text in it, just a black box covering that coirner of do I get rid of it?
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
Nov 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Loss of Signal
Check your connections from whatever you are viewing from.
Jun 13, 2017 | NEC PlasmaSync PX-42XR3A 42 in. HDTV-Ready...
The dogs rolled on the remote and the tv went to a blue screen and turned off. Every time you turn the tv on now it is a blue screen and says no signal and turns off after 10 seconds
This sounds as if when the dog rolled on your remote he has pressed the source button so that you are no longer on the TV cahnnel. The TV is looking for a different input eg. AV1/AV2/HDMI etc. This will give you a blue screen & as there is no signal the TV will switch off. Check on the remote for an Input or TV/AV or source button & make sure this is set for the TV signal.
Mar 22, 2009 | Vizio Televison & Video
Blue screen on the power up of LCD Sony bravia kdl26m3000
A blue screen usually indicates that you are on an input with nothing hooked up to that input.
Feb 22, 2009 | Sony BRAVIA KDL-26N4000 26 in. HDTV LCD TV
HD feed problem
this tv can only process 480p and 1080i as hdtv signal. Check your motorola to see if it is outputing something like 720p....
Sep 17, 2008 | Philips 30PW850H 30" TV
Blue screen
Try pressing the "Input" button a click at a time and see if the OSD (On Screen Display) cycles through Ant A, ANT B, AV1 and so on...
Nov 11, 2007 | Mitsubishi WS-73615 73" TV
Hitachi P50H401 50 in. Plasma HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
