Question about Danby DDR586R Dehumidifier
Water is leaking out of the bottom - Danby DDR586R Dehumidifier
  • Danby Master
  • 2,760 Answers
I get this complaint once in a while , most times it boils down to a unit that's being used on a Non level surface , most units are designed to gravity drain , if its not level , then Gravity is pulling wrong direction on unit so it drips on floor ;not in bucket
drips also can come from a frozen evap coil , this is a sure sign of blocked air flow and possible gas charge over heat (leak) unplug unit for 48 hrs to see if water continues to drain out , if so yep it's iced up
Posted on Jul 21, 2015
Why is my Frigidaire dehumidifier leaking water from the bottom of the unit?
Hi friend, thank you for your post!
I have identified that a few possibilities to why water is leaking from the bottom of your dehumidifier could be a crack inside your bucket or condensation from the bucket. I would remove your bucket and look it over to see if you can locate any visible cracks or chips. How much water is leaking from your dehumidifier? If you can provide any further information I look forward to assisting you. -Matt
Sep 03, 2014 | Dehumidifiers
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
There is a lot of water leaking out of the bottom of the ebac and not collecting in the unit.
try to check the water leakage or the origin where water comes from or maybe the area where unit locate was a very hi. humidity.
Feb 05, 2011 | Ebac Dehumidifiers
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
Water leaks from the bottom front under the bucket. Bucket does NOT leak. Attached a piece of tubing from the outlet to the bucket to no avail. still leaks. No visibe cracks anywhere.
Try cleaning the filter first. Wash it with water and let it dry overnight. Then make sure no debris is blocking the inside of the spiggot which fills the pan. The spiggot can get blocked by dust anddebris or insect webs. Clean thoroughly with a rag and your finger.
Oct 07, 2009 | Haier AHD50 Dehumidifier
Watwrleaks out of the bootom of the dehumidifier -
There should be a drain hose to drain water!!Check tank for leaks or obstructions-check that drain isnt clogged!!un clog and clean as necessary!!! Best of Luck!!!!
Jun 24, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Water goes in reservoir, not thru hose to sump pump, leaking
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
Dehumidifier m7dh65b2a
Mine leaks. Had leaked at other times but i took the vacuum cleaner to the front drain spout, that leaks into the removable basin. That worked in the past, but i't's not working now . The water is overflowing at the back of the catch tray and leaking out through the bottom underneath. The holes are clear, so it shouldn't be doing this. I am stumped.
Jul 04, 2008 | Maytag M7DH45B2A Dehumidifier
Leaking water
It sounds as though the collection pail is not installed correctly, or the hose fitting cap is loose. Make sure that the pail is seated correctly & the cap is tight. Inspect the bottom for rust perforation, too, although this is a long shot. If this fails, then the cold coil may have broken away from it's mount, & is dripping in the wrong place. Inspection with the cover off will reveal any misalignment or broken components. Repair as required.
Jul 17, 2007 | Maytag M7DH45B2A Dehumidifier
Danby DDR586R Dehumidifier Logo
265 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
