Question about Garden
Clutch troubleshooting - Garden
How do i troubleshoot my clutch system
No, the clutch and brake hydraulic systems are not connected.
If you are loosing fluid, you should be able to tell if it is leaking from the master cylinder where you add fluid, or the slave cylinder on the transmission.
Jun 18, 2015 | 1999 Ford Escort
How do I troubleshoot a z225 electric clutch?
unplug clutch at clutch jump clutch with battery dose it come on
Sep 17, 2014 | Garden
Harley troubleshooting
Does the noise happen only when you pull in on the clutch (disengage the clutch), and go away when you let the clutch out (engage the clutch)?
If so, that's the clutch plates rattling until the spring load is reapplied to clamp the up.
Aug 09, 2014 | 2010 Harley Davidson FLHX Street Glide
Is the clutch hydraulic or cable? in 80's peugeot's they had both depending on engine, if its hydraulic it could be failed seals or a leak, if its a cable it could have snapped, get somebody with a little mechanical knowledge to have a look.
Jul 29, 2014 | 1986 Peugeot 205 Cabriolet
Troubleshooting 92 geo storm clutch
It's time for new clutch set for your car. Good practice to always change the parts for clutch system. Clutch, pressure plate, throw out bearing.
Apr 21, 2012 | Geo Storm Cars & Trucks
My washer starts the wash cycle, but then will not go into the rinse and spin cycles. What do you think is wrong?
I think you have a clutch problem if the machine is FAV6800A or FAV9800A.
See this post for troubleshooting and a link to the Service Manual 5th post down in the thread.
If you want to troubleshoot open up a new thread in that DIY forum. I can't find my old post on this forum for Clutch Pulley/Outer Tub bearing issues. You need the Service Manual for the next steps of troubleshooting I would take you thru.........Rich
Feb 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
How t troubleshoot e blade clutch on a cub ZRT riding lawn mower
CK TO SEE IF YOUR GETING POWER TO THE CLUCH IF NOT THAN THE SWICTH IS BAD
Sep 28, 2009 | Garden
P 1750 cod come up. has shifting problem.
DTC P1750: Mechanical Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve Assemblies A and B, or Problem in Hydraulic Control System
NOTE:
• Record all freeze data and review General Troubleshooting Information before you troubleshoot.
• Keep these replacement solenoid valves on hand:
• A/T clutch pressure control solenoid valves A and B
1. Check whether the OBD II scan tool indicates another code. Does the OBD II scan tool indicate another code? YES - Perform the troubleshooting flowchart for the indicated code(s). Recheck for code P1750 after troubleshooting. NO - Go to step 2.
2. Turn the ignition switch OFF.
3. Replace the A/T clutch pressure control solenoid valves A and B.
4. Reset the PCM memory with the PGM Tester or by removing the BACK UP fuse in the passenger's underdash fuse/relay box for more than 10 seconds .
5. Drive the vehicle for several minutes in 1st, 2nd, 3rd, 4th, and 5th gears in the position.
6. Recheck for code P1750. Does the OBD II scan tool indicate code P1750? YES - Replace the transmission. NO - The problem has been corrected
Jul 08, 2009 | Acura TL Cars & Trucks
No clutch
You have a clutch cable on that model!
Jan 03, 2009 | 1991 Volvo 240
Garden Logo
448 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
