Question about Bionaire BAP1500-U Air Purifier
My remote control stopped working
The remote control has stopped working properly.  I can only turn on the unit everyonce in a while but cannot control the speed or turn it off with the remote control.
Please advise
thanx
  • 114 Answers
I do apologize for the inconvenience the only thing that i can suggest is the that whole unit will need to be reset. so the machine can connect again with the remote. also make sure that batteries are fully charged. If that doesn't work please let me know.
Posted on Aug 19, 2009
Indoor unit fan blows, then stops etc. every 1-2 minutes
At least it is cooling properly. U might just want to call Mitsubishi and ask them if it is operating normally based on your observations.
Apr 30, 2017 | Mitsubishi 18000 Btu Mr.slim Ductless Mini...
My Ionic Breeze Model S1637 just stopped working and I don't know what to do. Is there a solution for this. It appears as if the unit is not getting any power?
Test the outlet that it's plugged into, to make sure it's still functioning properly. There may be a loose connection at the receptacle or the circuit breaker in your home's circuit breaker panel, for that receptacle may have been tripped. If it is, before resetting it, make sure the air purifier is not plugged in to it. Then plug the unit in and turn it ON. If the circuit breaker trips again, there's a wiring short in the air purifier. Contact Sharper Image for possible repair or replacement.
Apr 04, 2011 | Sharper Image Ionic Breeze 3.0 Air...
I have an Aprilaire 700. Whenever the unit has been turned on, the water flow to the unit will not stop running. What part(s) do I need to replace so that the unit will properly turn the flow on and...
Hello, in order for the humidifier to turn on and off with the furnace you need either a sail switch or current sensing relay. A sail switch mounts in the return air duct and senses the return air when the furnace turns on thus turning on the humidifier and turning it off when the airflow stops. A current sensing relay works the same way but instaed of sensing airflow in senses current on the blower motors common lead and is easier to install than a sail switch. I will post a pic of both
robhvac47_24.jpgSail switch
robhvac47_25.jpg Current sensing relay
Feb 27, 2011 | Aprilaire Air Purifiers
Our Air Purifier stopped functioning and no longer turns on. We tried with different electrical plugs and that does not work either. Basilio Rodriguez 1001 E. Clark St. Warsaw, IN...
1) Make sure the plug in the back is inserted firmly.
2) The little switch by the plug should have the "I" end depressed and the "0" end up.
3) Check to make sure the back screen is inserted firmly, depressing the interior safety switch. (It will click when positioned correctly).
4) Try both the manual and remote controls. If the manual controls work, but the remote ones do not, check to see if the little plastic battery shield is still in the remote. Remove it by pulling on the little tab. If that's not the issue, also try a new battery in the remote.
5) Remove the plug in back, and pull out the fuse to see if it is blown. If so, replace it with the EXACT same size fuse, available at an auto parts store.
Jan 15, 2011 | Ecoquest Breeze AT Living Air Purifier
Unit blinks as if it wants to start put will not start fan starts moving and than stops repeately. Front panel buttons do not work some of remote buttons do
I would check the wiring connections to the fan and to the display board. Make sure they are seated properly. If that does not fix it, then call your dealer or the company and see what options you have. The company number is 800 989 2299.
Aug 31, 2010 | Ecoquest Fresh Air Air Purifier
Front display controls don't work
Sounds like the same problem I had with mine. I had to call and get an RMA number and they replaced the key pad, lcd display, and main board. This repair was covered under warranty. (Under 3 years old) They had it repaired and returned in about a week.
Sep 05, 2009 | Ecoquest Fresh Air Air Purifier
How to troubleshoot a Pure Ion #AP-75 non-working
My ionair cleaner doesn't clean the air what so ever. All four filters are perfectly clean after running for over two months. All of them are properly inserted and seated as specified. No filter warnings turn on and the unit works in all other ways. There is an ongoing fire in the hills nearby and our house if full of hazy smoke.
Aug 08, 2009 | Brookstone Pure-Ion UV Air Purifier
Stopped working
The problem most of you are describing is with the "TOUCH SCREEN" device. If it is cracked or broken the system detects a fault and goes into a default mode. I suspect that Brookstone is aware of this problem but did nothing to warn its customers. Nor did the company provide a source of repair parts. I have a model 506840 also and after cleaning it , the problem appeared. The unit was never dropped or mistreated but it is now inoperable. The best approach is to check the screen for cracks. Then check to make sure it is plugged in properly. I am trying to get some parts from Brookstone myself. But, so far no luck.
Sep 10, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Bionaire BAP1500-U Air Purifier Logo
267 people viewed this question
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
