Question about Home
Triton trance 2nd generation
The mains RCD fuse blew and now none of the lights on the shower work although they do flash when powered on, the unit itself is still operating without issue, can you offer any advice?
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Posted on Dec 15, 2008
  • 659 Answers
SOURCE: my shower works. water also poors out of a tube beneath the unit
Are you talking about water still coming through the spout at the same time? What overflow pipe are you talking about? If you are talking about the spout, there is a device in the spout that when you pull up on it, the water is diverted to the shower. They have washers in them and it sounds as though the washer is worn out and not making a good seal anymore. You can buy a new generic spout to stop the water or you can take the old one apart and try to find replacement pieces. I have taken one apart and bought a new one to rob the parts off of it before. I hope this is the answer you were looking for. If not, reply to this for clarification and I will try and answer your question more clearly.
Posted on Apr 03, 2009
  • 20 Answers
SOURCE: I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Posted on Nov 11, 2009
peterrance19
  • 399 Answers
SOURCE: triton jade 2 shower not generating sufficient heat
your element needs de caling i suspect
Posted on Nov 15, 2009
  • 16 Answers
SOURCE: triton topaz t80i. Power to unit ok, but no water flow.
sounds like the pump is broke. better off just replacing whole unit unless you order new pump from triton.
Posted on Jan 10, 2010
I have a triton trance 2nd generation electic shower that is a couple of years old when you turn the flow on it comes out red hot but as you increase the flow it gets colder as flow is increased what is...
Is it possible to have plumber come inspect? Warranty from purchase place? Since you don't sound you put it in I'm guessing a plumber did? It would've been new to him for the most part and he may have hooked something up wrong? You CAN DIY but realize that we're talking electric AND plumbing here. I'm thinking since it heats up the electric is fine. But check your man's work to see if it's got the 30-45A fuse on a dedicated circuit.
Steps
1.While out ay elect. box turn OFF by removing fuse or switching to OFF. Test unit that it only runs cold water.
2. Find shut off for water. Sometimes you have to shut off whole house! Hopefully somebody added a shutoff. Look on backside of shower for a 1'x1' hatch covering with a cold and hot valve. Turn water off. Test unit to see if it runs.
3. Now use the manual below and get in there and see if its hooked up right. Go slow and take your time. Retrace the install instructions.
Best wishes. Wear nitrile gloves for peace of mind!
DON'T do it if you're not aware of the electrocution issue. Water all over your bathroom (loo?) is one thing, a 230v shock is another!
http://www.tritonshowers.co.uk/media/640966/trance.pdf
Jan 11, 2015 | Home
My triton shower blew its fuse a couple of times and came back on when I 'flipped the switch' back up. Now it's given up altogether. What's the problem?
Assuming that the circuit and fuse protection you have is correct for the kw rating of shower unit the most likely cause would be an element failure however in order to be more definate relevent electrical checks would be required within the shower unit.
The Triton Service Dept who may be contacted by telephone on 0844 980 0750 would be able to arrange a sevice visit for you where the problem may be investigated further for you.
Regards,
Karl
TRITON TECHNICAL TEAM
Oct 05, 2010 | Home
No hot water
Check your fuse/breaker, should be a rcd switch. Depending when the shower was installed the fuse/breaker may be separate from the main fuse board, if it is an rcd switch it should be between 30A and 40A rating. If it is still fuse wire or cartridge fuse it should be replaced by residual current device.
Remember to turn the shower off in the bathroom before returning power to it.
Hope this helps
Apr 10, 2010 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
Turned on a triton trance electric shower it was working ok then it stopped coming out of the shower head and coming out of the overflow pipe at the bottom of the shower unit
The overflow pipe is a pressure relief device which is a small rubber ball that get's ejected when the water pressure inside the shower is too high. You will need to get a spare part to replace this. These generally operate because the showerhose is in poor condition and has collapsed internally, or the showerhead has become clogged up so check these things first.
Good luck.
Sep 21, 2009 | Kitchen Appliances - Others
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Home Logo
32 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
