Question about Simplicity Garden
How do you adjust valves on an 18 hp v-twin Kohler engine?
Need to adjust valves for better running engine on 1996 Simplicity tractor
5 Suggested Answers
boscia
  • 163 Answers
SOURCE: How to adjust the idle on my lawn tractor
there should be one screw at the top of the carb, that is the fuel intake adjust screw. turn clockwise all the way down without force. start the mower and slowly turn clockwise until rpm sound right
Posted on Nov 30, 2008
  • 3074 Answers
SOURCE: I need to find a
take the shroud off and replace the magneto
Posted on Oct 30, 2010
SOURCE: i have a craftsman kohler magum 18 hp twin
I had the same problem with my tractor.same tractor and everything.all u have to do is you know the wires that hook up to your seat?them 2 wires cant be touching eachother.if them 2 wires that hook to your seat r touching eachother,it will stall out when u let out the clutch.
Posted on Apr 19, 2012
  • 6468 Answers
SOURCE: I have A craftsman Model 917.273470 with a Kohler 20 Hp V-Twin. It will run if I spray gas in the carb. Drained old fuel, replaced fuel filter, checked gas flow into carb with pressure guage, Cleaned
check the solenoid on the bottom of the carb check for movement and power if it moves and has power open the carb and clean it
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18 hp kohler engine starts but doesn't keep running!!!!
You put in a question about your ride on. What is it you need?
Aug 15, 2014 | Kohler 18 Hp OHV V-Twin Command Engine
How do you change the arbor bearings on an simplicity regent with a 50 inch cut?
You must take the blades and belt off and the well as pulley, the arbor is replaced as a unit and it unbolts with several bolts.
Jul 28, 2014 | Simplicity Regent Riding Mower 23 HP...
Valve clearances
mine has hydrodrolic lifters no adjustmetn
Aug 21, 2012 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I have a craftsman kohler magum 18 hp twin tractor.it runs fine until u release clutch then it dies why?
May 01, 2011 | Craftsman Garden
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
I need an owners manual for a craftsman 18 hp kohler mag twin 44 in deck model 917-257720. thank you
You can access the parts list and see the diagrams at Sears parts direct. I think its also printable. There will only be a part list for the tractor itself,not the engine.
YVW
mike
Oct 22, 2009 | Garden
Garden Logo
13 people viewed this question
Top Simplicity Garden Experts
Dennis Key
Dennis Key
dannydoesita
Will Mishler
Will Mishler
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
