Question about Razor Dirt Quad Bike
Brake hanging Brake sticking
2001. Why is right rear brake sticking?
what shape is the rotor in. is it built up with rust. is any caliper mountings bent how about the e-brakes are they hanging up causing the brake to not be fully off.
Aug 14, 2015 | GMC Jimmy Cars & Trucks
Replaced brake pads on 2004 silverado now both sides are sticking
You can't put new pads on & not turn the rotors
You have to remove all rust from both sides of rotor,
wheel hub face,pad & caliper abutements,slipper,siding
surfaces & lube moving parts
There is more to brake maintenance or service than hanging
a pad as the brake places do,then you have problems
Feb 01, 2013 | Cars & Trucks
Chevy cavalier jerks when stopping
Possible brake issue caused by warped rotor or sticking brake caliper. If it pulses when braking have the rotors turned or replace them. Would also replace the brake pads while you have it apart. Old pads should be the same thickness for both inboard and outboard pad. If one is thinner than the other it is an indication that the caliper is sticking or hanging up.
Jan 12, 2013 | 2001 Chevrolet Cavalier
1991 dodge dakota front brake sticks when driven 15 or 20 miles and pulls hard to the left
check the caliper it may be hanging up also check the rubber brake hose sometimes they collapse or swell causing drag either way you probably need 2 calipers and new lines(hoses) along with pads.
Aug 22, 2012 | 1991 Dodge Dakota
Emergency brake may not be properly releasing: 03 Pontiac Sunfire.
need to remove rear brakes and check brakes and or e-brake may be hanging up or sticking also check for broken or stuck part
May 13, 2012 | 2003 Pontiac Sunfire
Pulls sharply to the left when brakes are applied.
Front disc brake calipers are hanging up or a faulty suspension or steering part.
Aug 10, 2010 | 1994 Chevrolet G20
Dropped brake caliper now the brake piston is sticking ,could i have messed the brake line up ,thecaliper was hanging by the brake line
Most likely not,the caliper,or the brake hose is the problem,pump up the brake pedal,and see if the wheel will freeze up,when you release the brake pedal,if so,brake loose the bleeder on the caliper,if the caliper frees up,then the brake hose is the problem,if it does not free up,replace the caliper.
Mar 13, 2010 | 2003 GMC Sierra 1500
1989 Honda prelude brakes sticking.
pistons in brake r sticking need to b stripped n cleaned
Nov 16, 2008 | 1989 Honda Prelude
Ford Escape 2001 model - brake pedal sticking
What pushes the pedal back when you release the pedal is a strong spring inside the master cylander that pushes on the piston that moves the brake fluid to the calipers and wheel cyls. This spring should last the life of the master cyl. and replaceing the master cyl. is the only way I know of to replace your weak spring or a piston that is hanging up. Check all the linkage under the dash to be sure that there is not a problem with your pedal linkage that is causing your problem
Jun 23, 2008 | 2001 Ford Escape
Razor Dirt Quad Bike Logo
77 people viewed this question
Top Razor Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
ray gallant
Betty L Kidd
Betty L Kidd
Are you a Razor Rock and Ice Climbing Expert? Answer questions, earn points and help others
