Question about Panasonic Lumix DMC-FS15 Digital Camera
System error focus on display window - Panasonic Lumix DMC-FS15 Digital Camera
Hi! i am trying to detect a problem in my sony model HCD-GZR777DA when switch it on, after waiting it display c 31 00. where to start please help
31: DPD offset adjustment error .
Contact any service technician. You can't repair this. The error code list to this set:
The meaning of error code is as below:
01: Communication error (No reply from syscon)
02: Syscon hung up
03: Power OFF request when syscon hung up
19: Thermal shutdown
24: MoveSledHome error
25: Mechanical move error (5 Changer)
26: Mechanical move stack error
30: DC motor adjustment error
32: TE balance adjustment error
33: TE sensor adjustment error
34: TE loop gain adjustment error
35: FE loop gain adjustment error
36: Bad jitter after adjustment
40: Focus NG
42: Focus layer jump NG
51: Spindle stop error
52: Open kick spindle error
60: Focus on error
61: Seek fail error
62: Read Q data/ID error
70: Lead in data read fail
71: TOC read time out (CD)
80: Can't buffering
81: Unknown media type
Are you confident to do anything with these error displays.
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Sony Audio Players & Recorders
Panasonic LUMIX DMC-FH4 is showing system eror focus. How solve it ?
Can you tell exactly what is on the screen please. The system error focus is not supposed to be an real error that is displayed on your camera.
"System error" is possible. But if switching of and a few moments later switching on does not change the error on the dis[lay, you should contact a Panasonic certified repair centre.
May 24, 2014 | Panasonic Lumix DMC-FH4 Digital Camera -...
CD player doesn't read and it displays disc/focus error check disc
most common cause is a dirty or bad optical pickup in the unit, it may be able to be cleaned but more common is the pickup is bad.
Dec 18, 2012 | 2007 Nissan Altima
Blue screen appears at start up boot screen and restarts again
press "F8" while statrting , and then select "safe mode"
Feb 01, 2011 | Computers & Internet
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
Images are blurred
Blurred images can have different reasons. Greasy lens, camera shake or focus error.
You can clean a greasy lens with a lens-cleaner solution and lens-paper.
Camera shake will (most likely) only occur on images taken without the flash. Most likely there will be a warning on the display if risk of shake. it's a hand with an "!". Focus error will usually also give a warning in the display.
May 09, 2010 | Fuji FinePix S2000hd Digital Camera
I WANNA INSTALL XP2 BUT MY SYSTEM SHOWS ERROR: C000022UNKNOWN HARD ERRORSYSTEMROOTSYSTEM32NTDLL.DLL
  1. This problem may occur if the file that is described in the error message is corrupted. The following files are checked for integrity when Microsoft Windows XP starts:
  2. All driver files (except those that are loaded by the system loader to start. the computer)
  3. All dynamic-link libraries (DLLs), including User, Graphics Device Interface (GDI), Shell, Kernel, Ntdll, Crtdll, and others.
  4. This problem may occur if you install an inappropriate driver for your hardware. For example, you receive one of the error messages that are described in the "Summary" section if you install a MIPS driver on an X86-based computer.
    This problem may occur if an Iomega Zip drive is on the same integrated device electronics (IDE) cable as the hard disk drive.
  5. To resolve this problem, obtain a new copy of the corrupted file or reinstall Windows XP. If you continue to receive any one of the error messages that are described in the "Summary" section after you reinstall Windows XP, a hardware problem or a network problem may exist.
  6. This error message may be displayed in many different formats, including an error message that is displayed on a blue screen or an error message that is displayed in a dialog box. The type of format that the error message is displayed in depends on how much of the operating system was loaded when the corrupted file was detected.
Apr 11, 2009 | Microsoft Windows Vista Ultimate Edition
My camera is showing the error code E:61:00
On Sony equipments this error code seems to be dedicated to focus and lens errors. You may have either some dirt or anything like this inside the lens or focus mechanism, or a broken mechanism (any drop of your camera lastly ?).
If you can open it properly, you should check for "foreign body" inside the mechanism (focus and zoom mechanism, but but code 00 means focus normaly).
Jan 16, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Touch Focus Error
Even if the pix appears to be "OK", the internal convergence
alignment (in servicer mode) must be accurate within certain
parameters for the Touch Focus function to complete w/o error.
Adjustments should be done in "Full" mode,both HD & regular
signal.
Oct 13, 2007 | Toshiba 53H71 53 in. Rear Projection...
Panasonic Lumix DMC-FS15 Digital Camera Logo
18 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
