Question about Lexmark X3470 All-In-One InkJet Printer
Lexmark x5470 incorrect port detected - Lexmark X3470 All-In-One InkJet Printer
hemantraj
  • 638 Answers
SOURCE: Incorrect Port Detected
  1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
  2. CHANGE THE USB WIRE (THE CONNECTION BETWEEN PRINTER AND YOUR PC )IF IT IS TOO OLD.
  3. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  4. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  5. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  6. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  7. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  8. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  9. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
Posted on Jun 08, 2008
wolfungarman
  • 148 Answers
According to Features and Specs on Lexmarks website, this is a All in One? i.e Fax, Printer, Scan & Copy? also it's a Network type?
If so have you chosen the correct settings via the Printers Dispay and Control Panel? ...... I assume you have and everythinh in Device manager looks good, i.e no Yellow and or Red Icons over anything listed there, especially USB....correct?
If your Vista is the 32 Bit then the driver file should be: cjb5000enOSS.exe (87.7MB)
If Windows Vista x63 then it will be: cjq5000enOSS.exe (132.76MB)
Hope the above helped,
cheers,
Bastian
Posted on Jun 02, 2009
ginko
  • 19396 Answers
SOURCE: how do i connect my lexmark x5470 with out cd software
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Soulvisitor
  • 1113 Answers
SOURCE: I have a Lexmark x5470 & I get an error unsupported cartridge
Ink cartriges have chips in them, if the printer does so many prints without getting the "I've had a new Original Cart fitted" it will stop untill,you give it one, regardless if there ink or not
Im afraid it doesn't care that you only need to use the colour cartridge, it is designed to cost you money and make money for lexmark not refillers.
Welcome to our modern world, manufactures make the ink hard to recycle by incorperation of expensive chips that makes refillers, unable to make a easy dollar, because if that want to make cartridges that work they must also fit the expensive chip.
All empty cartridges have a little ink left in them because getting air in ink lines is not a thing we want.
Posted on Nov 07, 2009
MUKHTAR
  • 2017 Answers
SOURCE: left cartridge incorrect for lexmark x5470
Check to see if the installed cartridge is the correct one for the printer. . If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact to Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Have a nice day and do not forget to rate please...!
Posted on Feb 11, 2010
Lexmark X5470 Right Cartridge Incorrect messagem
This article in the Lexmark website will help you identify and resolve the "right cartridge incorrect" error message: Cartridge Errors on the Lexmark X5400 Series Printers
Apr 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
My lexmark 4300 series says incorrect port detected
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
Jul 23, 2010 | Lexmark All-in-One Printer with PictBridge
MESSAGE SAYS RIGHT CARTRIDGE INCORRECT
Hello there:
what this is refering to is that the cartridge is either not the right one for the printer or the device is having a problem with that cartridge i would remove the cartridge and verify that it is the right one that goes in their and also since youare having the cartridge out i would clean out the contact area to get rid of the old ink that may be sitting on the contact areas ok
best regards Michael
Nov 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Help! my lexmark x5470 all-in one says right cartridge incorrect!
this is may be you using the refill or incompatible catridge. i advise you to use genuine catridge.
Nov 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a lexmark X5470 bought a lexmark #33 color cartridge. the printer states: right cartridge incorrect. at the store it said that it is compatable with my printer. how do i get my printer to work?
According to the Lexmark site an number 33 color cartridge is the correct color cartridge for the printer.
Are you trying to print potographs? If so, then you would need the #32 cartridge and the color cartridge together in the priter.
If you believe that the cartridge is defective, contact Lexmark at 1-800-232-3000 and let them know you received a defective cartidge.
Don
Jun 09, 2009 | Lexmark X5470 All-In-One InkJet Printer
cheers,
Bastian
Jun 02, 2009 | Lexmark X5075 InkJet Printer
Lexmark says inncorrect cartridge
chage both the cartridges as u have changed 1 also change another as its not getting detected.
Dec 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 Printer
The messages Appears when the catridges are not inserted correctly........ Install the Colour Catridge on the Right Side and the Black should go in the Left Side...... Thanku
Jun 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
