Question about Carters Elephant Parade Blue And Brown Cuddle Me Musical Swing
How do I operate my Carter's swing?
Need owner's manual. Don't know how to operate.
I would like to know if you have a carter carburator diagram for a 2bbl carb
Www.carter.com ask for exploded views of your carb you'll need the tag number on the carb. Its relatively easy to do as long as your float level is correct or google carter carberators using the tag number
Feb 06, 2015 | Cars & Trucks
I have a Skytech 3301 for a propane stove with some thermostat problems.
Great question! It sounds to me like the Skytech's swing temp setting may be out of whack.
Here is a quick link to the product page with a link to the owner's manual at the bottom if you need: Skytech 3301 Fireplace Remote.
Below is an excerpt on how to check and modify the swing temp settings for the Skytech 3301. (I apologize if the copy/paste formats poorly).
The Thermo Mode on the transmitter operates the appliance whenever the ROOM TEMPERATURE varies a
certain number of degrees from the SET TEMPERATURE. This variation is called the "SWING" or
TEMPERATURE DIFFERENTIAL. The normal operating cycle of an appliance may be 2-4 times per hour depending on how well the room or
home is insulated from the cold or drafts. A smaller "swing number" increases the number of cycles so the room temperature is more
constant. A larger "swing number" decreases the number of cycles, which saves energy, in most cases. The factory setting for the "swing
number" is 2. This represents a temperature variation of +/- 2
0
F (1
0
C) between SET temperature and ROOM temperature, which determines
when the fireplace will be activated. The "SWING" number values are:
1=+ 1
0
F (.5
0
C), 2= + 2
0
F (1
0
C) and 3 = + 3
0
F (1.6
0
C).
SETTING THE TEMPERATURE SWING (TEMPERATURE DIFFERENTIAL)
1. To change the temperature "SWING" setting (1-3), press the TIMER/TIME and DOWN buttons
simultaneously to display the current "SWING" setting in the SET TEMP frame. The letter "S" will
display in the ROOM TEMP frame on the LCD screen.
2. Press the UP or DOWN button to change the temperature differential or "SWING" (1-3). See above
for 1-3 "SWING" temperature valves.
3. To store the "swing number press the SET button or allow 15 seconds to lapse, and the new "swing
number' will be automatically programmed.
MANUAL CHECK OF " SWING" OR TEMPERATURE DIFFERENTIAL
The operation of the factory set "THERMO SWING" can be checked by adjusting the SET TEMP 2
0
F above or below the room temperature.
This will cause the system to turn ON or OFF. Normally the system will only respond to temperature changes every two minutes. Manually
changing the SET temperature will activate the system in less than 10 seconds. IF the "SWING" is changed, then a new room temperature
differential will respond. Factory setting of "SWING" temperature is 2
0
F.
Jan 17, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
Wiring diagram for 2007 yamaha vstar 1300
Hi, Carter for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Wiring diagram for 2007 yamaha star 1300 Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha XVS1300A 2007 Service Manual
OEM parts for Yamaha
Yamaha 2007 XVS1300AW Owner Manual
Jul 28, 2012 | 2007 Yamaha V Star 1300
Need a wiring diagram
2010 Yamaha Star 1300 Tourer wiring diagram Google Search
Yamaha XVS13AWC Service Manual
Jul 28, 2012 | 2010 Yamaha V Star 1300 Tourer
Where is the fuse box located on a 2006 ford explorer
There are 2 places that have fuses on your vehicle. I'm guessing since you don't know where the fuse panels are that you do not have an owners manual. Fords are only done by number and you need to look at the owners manual or other sources in order to know what each fuse goes for. Below I have given you a picture of the location of each fuse box as well as a picture of the layout of the fuses along with a desciption of what each fuse goes for by number. I hope this helps and good luck.
Sep 09, 2011 | 2006 Ford Explorer
The sunroof on my 2006 Lincoln Zephyr is tilting and sliding on its own. Dont know where the owners manual is.
Don't need an owners manual to push the button, to
actuate the sunroof
Maybe you have the owner manual with your
preventative maintenance log book ,where you
write down all you do on the car
If it won't operate correctly, you need a repair shop !!
Jul 14, 2011 | 2006 Lincoln Zephyr
I need the owner's manual to a Simmons model 1250 coated optics telescope.It was given to me but i don't know how to set it up or operate it.please help me! ...
Sorry no owners manual for that scope. However Bushnell has all of their manuals on this web site-- find a scope similar to your scope-- they all assemble and are used in a similar fashion.
http://www.bushnell.com/products/other-products/telescopes/instruction-manuals/
Jun 12, 2011 | Optics
Samsung 34 X optical zoom digital 1200X I need owners manual please. I don't know how to operate it
Click over image to download your Samsung-Camcorder-SCMX20ER-User-Manual...
Hope helps with this (remember to rate and comment this answer).
May 29, 2011 | Samsung Cameras
Carters Elephant Parade Blue And Brown Cuddle Me Musical Swing Logo
27 people viewed this question
Top Carters Baby Gear Experts
Dorel UK
Dorel UK
Are you a Carters Baby Gear Expert? Answer questions, earn points and help others
