Question about Magimix Kitchen Appliances - Others
Lid wont close - Magimix Kitchen Appliances - Others
Green canister lid wont close
http://smallappliances.electroluxusa.com/en-US/Customer-Support/
download free your instr manual and see your problem lid why not close, go to the section troubleshooting.
God bless you
Sep 27, 2012 | Electrolux Ultrasilencer Green Canister...
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
Wont drain or spin
Does it click when closing the lid ? Sometimes , the lid switch arm , will work inserting something into it , but not with the lid closed . Try checking it useing the lid itself . Occasionally , the arm wears to where it has to be pushed farther down to work so the actuator on the lid cannot push it far enough down .if you have to replace the lid switch for it to work properly or bypass the lid switch it needs to be from under the console .do not drop screws in between the tubs
Aug 16, 2009 | Kenmore 24032\24036 Top Load Washer
Washer is filled with water,,it wont drain,,nor
Sounds like a bad lid switch. When you close the top lid, there is a safety switch that closes, it is actuated by a pin attached to the lid, there will be a small hole located on top of the machine, somewhere on the perimter of the top of the tub. Could also be a bad timer.
Jun 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
Chest freezer lid
Vacuum is caused by contraction of air. If your temperatures are being maintained the difference in how easily the lid opens and closes is not a point to worry about. If the lid wont shut after it is opened you do have a problem. If the lid is staying open at one corner try, with the lid open give it a slight twist pulling on the corner that is not closing fully. This action should spring the lid back to its original sealing position.
Jun 12, 2008 | Freezers
It wont finish washing
open and close the lid a few times. can you hear any clicking noises, you should hear the lid engaging the lid switch. if the machine doent think lid is closed it wont funtion( safety reasons)
Feb 27, 2008 | Maytag LSE7806A Top Load Stacked...
Washing machine
sounds lilke a bed lid switch for safety reasons it wont spin if it thinks the lid is not closed. open nd close the lid carefully agian and again, as your doing it do you hear a clicking noise??? if not your not contacting lid switch
Feb 25, 2008 | Whirlpool LSR6334LQ Top Load Washer
Kitchen Appliances - Others Logo
63 people viewed this question
Top Magimix Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Magimix Kitchen Appliances - Other Expert? Answer questions, earn points and help others
