Question about Bose Lifestyle 18 System
SA-2 and SA-3 doesnt work together
I hava a lifestyle 18 system. A SA-2 amp is connected with speakers and works fine. Trying to connect SA-3 amp with another set speakers(outdoor) in serie after SA-2 but doesn't work. The SA-3 works fine as the first amp instead of the SA-2. What to do? Kurt-Inge
  • 92 Answers
Its alwaays better just to call bose their great when it comes to this
Posted on May 20, 2009
My Bose SA3 2 channel amp keeps blowing when I raise the volume with non-bose speakers, why is this happening?
Could be the impedence of the speakers that you're connecting. The bose amp was designed to drive 8 ohm speakers.
Aug 31, 2016 | Bose Lifestyle SA-3 2-Channel Amplifier
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
Bose link AL8 will not connect with the Lifestyle homewide powered system
Your v35 system needs to be programmed to work with the second zone wireless unit. Read the instruction manual how to do it, or let a Bose dealer set it up for you.
Dec 27, 2013 | Bose link AL8 wireless home-wide audio...
Bose rc48s2 remote not receiving signal
make sure the lens on the remote and the one on the Bose are clean. If that does not work, replace the remote. Buy a used on on ebay.
Dec 21, 2013 | Bose RC-48S Remote
My Bose lifestyle amplifier (SA-2, SA-3) suddenly stopped working while playing stored music. It has worked flawlessly for over 3 years until now. I replaced the batteries in the remote and checked all...
Check your settings on the main system setup mode and make sure the amp is enabled. If you still have an issue, post a comment and I can help you further.
May 30, 2011 | Audio Players & Recorders
Bose SA-3 amp and a non bose sub.. I keep blowing the amp..
How many ohms is your sub? The SA 3 Amp can only handle speaker(s) 6 ohms and greater. A lot of subs, as I understand, are 2 and 4 ohms typically. If yours is 2 or 4 ohms, then that explains it. The speaker would be "straining" your amplifier and blowing it.
Oct 02, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
Want to test to see if bose lifestyle 18 works.
Hi sorry but what do you mean that you have lifestyle 18 system? The lifestyle 18 system consist of the media center/DVD player, the bass module, the satellite speakers and the RF remote control (aside from tons of cables)
If you have the media center/DVD only, then you require the power adaptor. you can test if the media center is functioning if the LCD display is working. you can also connect an external powered speaker or an amplifier fro mteh AUX out behind the media center.
Do note that doing so will only give you limited control of the system since you require the whole lot to make everything work properly.
Glad to be of service.
Jan 27, 2009 | Bose Lifestyle 18 System
No sound from rear speakers on the lifestyle 18
The SL2 works in such a way that the speaker satellite out put from the bass modules is fed to the input of the SL2 transmitter (remember, transmitter) then the sattellitespeakers are connected at the other end of the room to the receiver. An initial blinking green light should be seen and once the system is turned on this turns into steady green. Both the SL2 transmitter and receiver operates via WIFI.
Glad to be of service...
Dec 21, 2008 | Bose Lifestyle 18 System
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
Bose Lifestyle 18 System Logo
314 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
