Question about GE AJCQ08ACB Air Conditioner
Power will not turn on
The power will not come on on My GE AEW10AJS1 i have tried resetting it and testing the outlet, which does work. i tried turning on the air conditioner from the botton on the front panel and from the remote neither works
  • GE Master
  • 4,654 Answers
If you know the outlet is good then you need to unplug the AC slide it out of the cabinet and see if the on off switch is working or if there is a loose or burned connection in the wiring circuit. check all wiring going and coming to capacitors and check to see if the continuity between the post on the control switch. There are many different models and each one has different features. So each one may be wired a little different. While you are inside the cabinet mart the wires going to compressor and where they connect. Let me know when you get to that point and I will lead you through the way to test the compressor. I don't think the compressor is the problem, I just want you check all connections for burns or bad connections, Thanks, Sea Breeze
Posted on May 21, 2009
My washer wont fill up orturn on
First test the outlet your washer is plugged in to..it is likely a ground fault interrupter outlet that may just need to be reset. You can try plugging a known working item such as a small lamp or power tool into the outlet your washer uses to make sure it is working. If the outlet is dead and does not have a reset button, Check your circuit breakers.
Sep 26, 2014 | GE WBSR3140DW Top Load Washer
My dryer (DBVH520EJ2WW) will not turn on. No lights, no beeping - nothing. There was a lighting storm and it hasn't worked ever since.
Often the dryer is on it's own circuit, is there a breaker on the outlet? try to reset it. Or in your breaker box, test each one. Check that the outlet has power.. plug in a lamp or somthing..
If no joy then you might need a repair person to come in, possibly need a control circuit board.
Aug 15, 2013 | GE Dryers
Ge smart timer-won't work after I changed off/time-no voltage to light
Hello Terry. Which GE digital timer do you have?
Copy following link to identify timer, and download manual.
http://waterheatertimer.org/GE-timers-and-manuals.html
Reset timer using reset button.
If timer has no voltage, then check outlet.
Check circuit breaker.
Check that light bulb is good.
If timer is plug-in type, then test outlet with circuit analyzer. Try timer in different outlet with different light.
Re-post question with timer model number, and things you have tried so far.
Jul 15, 2012 | Hardware & Accessories
This ge model aew10ajs1 keeps shuting off an doing its owen thing i checked for loose wires an the outlet is good the coil is a little dirty but not bad
the motor may be overheating due to a clogged filter. there are temperature switches in them that are safety switches in them to keep them from catching fire.
Aug 12, 2010 | GE Vacuums
New GE electric kettle causes wall outlet to stop working.
Your electric kettle in drawing more current than your wall outlet's are made for. Not being able to read your current draw on your GE kettle I would guess you have a bad GE kettle and it needs to be returned to where you bought it.
Oct 09, 2017 | General (102105011) Electric Kettle
EP Message - no cool air on a GE Air Conditioner
I just posted this on another one, but try unplugging it and pushing the reset buttons on the side of the plug. It worked to fix mine so far...
Jul 27, 2009 | GE Heating & Cooling
GE AEW10AJS1 Window Unit A/C Shuts Off and Trips Reset.
The condenser coils may be dirty. You can wash them out with a hose or compressed air.
Jul 20, 2009 | GE AJCQ08ACB Air Conditioner
AEW10AJS1 a\c digital panel keeps climbing to its
I have the same problem, 4 little kids in the house trying to keep them cool. Did you find out how to fix this?
thanks
Ian
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
Air conditioner model AEW10AJS1 wiring problem.
That is the temp prob it belongs in the air flow, its only connected on one end
Mar 29, 2009 | GE AJCQ08ACB Air Conditioner
GE AJCQ08ACB Air Conditioner Logo
351 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
