Question about Haier HL19D2 19 in LCD TV
Hdmi invalid format
Hdmi not working on haier hl 19d2 but working on sansung 4003
Invalid format screen
Check the input source to make sure it is set to HDMI.
Dec 30, 2013 | LG 50PJ350 50 in HD-Ready TV
Red spots screen
you have one of the cables in the wrong input. keep trying till you get it right
May 07, 2013 | Haier HL32D2 LCD 32-inch TV with piano...
Invalid format on hdmi
Unplug set, HDMI, and a box if used for a while--connect the HDMI first and then power to set and or box--see if set will reboot or box.
HDMI does not like power loss, being connected or disconnected with power on etc.
Also in set menu make sure HDMI input is "available".
Apr 29, 2012 | Olevia Televison & Video
Invalid format error with P1600 blu-ray and LG LCD TV 42"
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
Jan 17, 2010 | LG 42LC2D 42 in. LCD HDTV
I have an LG 42LC2D TV with INVALID FORMAT ON HDMI2
I have had this same issue.
Problem your tv isnt true 1080p meaning it will not work however when you switch to componet cables goto menu then change the display settings to 720p or 1080i then your HDMI connection should work fine.
Dec 12, 2009 | Televison & Video
I have a LG 42PC5D Invalid Format on Screen HDMI VGA and PC
I have a LG plasma and I am trying to connect my PC via VGA and I am getting the "Invalid Format" - can you please tell me what is the problem? Thank you
Aug 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
Invalid format
Try rechecking all wire connections for proper placement and fit too and from the tv.
Try adjusting the video format on the DVD, flip through 480p and 1080i. See which format works best with your tv. Do the same with Wii.
See if this helps.
Jun 13, 2009 | LG 42LG70 42 in. LCD HDTV
Hd tv doesn't work at all says invalid format
is the tv 720 or 1080. it wont work if your inputing 1080p to 720p or 1080i
Dec 11, 2008 | LG 50PC1DR 50 in. Plasma HDTV
Haier HL19D2 19 in LCD TV Logo
26 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
