Question about Lego Media Toys
Replacing speedometer cable - Lego Media Toys
98Chevy tracker speedometer doesn't work
The speedometer cable mechanically drives the speedometer and the odometer
Remove the instrument cluster assembly. Refer to Instrument Cluster Replacement .
Unhook the speedometer cable from the heater case.
Remove the grommet from the bulkhead.
Feed the speedometer cable through the bulkhead.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Unscrew the speedometer cable (1) from either the transfer case or the transmission.
Remove the speedometer cable (1) from either the transfer case or the transmission.
Remove the speedometer cable (1) from the clamp.
Remove the speedometer cable (1) from the vehicle.
Jan 20, 2017 | 1998 Chevrolet Tracker
How do you replace the speedometer cable in a 1998 chevy tracker
Removal Procedure
  1. Remove the instrument cluster assembly. Refer to Instrument Cluster Replacement .
  2. Unhook the speedometer cable from the heater case.
  3. Remove the grommet from the bulkhead.
  4. Feed the speedometer cable through the bulkhead.
  5. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Unscrew the speedometer cable (1) from either the transfer case or the transmission. Remove the speedometer cable (1) from either the transfer case or the transmission. Remove the speedometer cable (1) from the clamp. Remove the speedometer cable (1) from the vehicle.
Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
Disconnect the negative battery cable. Remove the hazard lamps switch by gently pulling the knob straight up. Remove the instrument cluster bezel from the instrument panel. Refer to Instrument Panel Cluster Trim Plate Bezel Replacement . Remove the 4 screws and pull the instrument cluster assembly forward from the instrument panel. Disconnect the 3 electrical connectors. Remove the speedometer cable at the speedometer head. Remove the instrument cluster assembly from the vehicle.
Remove the 5 screws (2) and the steering column upper and lower covers (1, 3).
Remove the 4 screws and the instrument cluster bezel from the vehicle.
Jun 17, 2015 | 1998 Chevrolet Tracker
Speedometer cable replaced still have speedometer flutter
1989 Mustang speedometer is cable drive so VSS will not affect.
If over 140k miles the speedometer is likely worn out.
My company SpeedometerRepair.com can repair or another speedometer shop.
Feb 19, 2015 | 1989 Ford Mustang
1982 goldwing odometer and speedometer stopped working
Check your speedometer cable, detach it from the speedometer elevate the front wheel and spin it notice the inner cable if it turns or not, if not replace the cable if it spins then replace the speedometer.
Nov 02, 2012 | Honda Motorcycles
My speedometer didnt function anymore, i need to replace the whole assembly of my speedometer.
No I believe the speed ometer cable is broken.Dissconnect sppedometer cable from instrunent cluster,romove cable from back of speedometer &transmission case .romove speedometer from sppedometer cable housing if broken replace with new & make sure you grease cable when installing back in cale housing reconnect to transmission &back of speedometer.keep posting
May 23, 2011 | Nissan Frontier Cars & Trucks
1990 Legacy: speedometer not working...
The first thing you can always do is check your fuses. there might a blown fuse that need replacement.The 1990 Legacy has a mechanical speedometer . The speed sensor is a read switch in the speedometer head itself. So if your speedometer is functioning ( needle working properly ) then the internal read switch is defective. That requires replacing the entire speedometer OR it can be a defective connection between the speedometer and the ECU.If the speedometer is not working, then you can have a defective speedometer, cable, speedometer cable adapter ( on the tranny ) or internal speedo gear in the tranny. Thanks. you can rate this solution and show your appreciation.
May 17, 2010 | 1990 Subaru Legacy
I have an 1992 88 oldsmoblie and my speedometer stop working whats wrong
Unscrew the speedometer cable from the side of the transmisson. Pull the cable out of the transmisson. While someone else sits in the drivers seat and looks at the speedometer you turn the end of the cable quickly. If the speedometer doesn't move the cable is faulty. Replace it
To check the speedometer only disconnect the cable from the speedometer and insert a small screwdriver.Turn the screwdriver quickly. If the speedometer doesn't move then the speedometer is faulty and must be replaced.
Feb 23, 2010 | 1989 Oldsmobile Delta 88
Broken Speedometer on my '84 S-10.
HI. If your speedometer needle doesn't move, or if it flutters, your speedometer cable may be bad.
To determine if it is the cable, disconnect the cable casing from the transmission and from the back of the speedometer on the instrument panel. Draw the cable out from inside of the casing. The cable looks like a twisted piece or wire. If the cable is broken or if it is dry or brittle. It probably needs to be replaced. If the cable is intact and the same length as the cable casing, the problem is likely the speedometer head.
I would also advise to check the speedometer gear as well.
The speedometer gear is located on the output shaft. Inspect it for damage.
This gear rarely suffers damage because the gear from the speedometer that meshes with it is usually made of a softer material. Sometimes, the speedometer gear on the main-shaft is replaceable. A clip can hold it in place or it can be a pressed fit. A special puller is available to pull these gears on the car.
Nov 08, 2009 | 1984 Chevrolet S-10
Speedometer wont work
This gear rarely suffers damage because the gear from the speedometer that meshes with it is usually made of a softer material. Sometimes, the speedometer gear on the main-shaft is replaceable. A clip can hold it in place or it can be a pressed fit. A special puller is available to pull these gears on the car/truck.
Mar 12, 2009 | 1989 Chevrolet C3500
Replace speedometer calbe
Replace the Speedometer Cable
1 - Remove the old speedometer cable from your car, first take off the doghouse and then the engine cover.
2 - Remove the screw underneath the dashboard and take down the steering column. This will give you access to the back of your speedometer.
3 - Take off the drive shaft bolt, and "O" ring, insert the speedometer cable through the firewall.
4 - Remove speedometer cable securing clamps from the engine compartment and on the transmission.
5 - Release the drive shaft nut from the "right angle" adapter (The nut is attached to the back of the transfer case).
Installing the Speedometer Cable
1 - Place the square end of the speedometer cable into the adapter and secure the drive shaft nut.
2 - Pull the speedometer cable through the firewall to the rear of the speedometer.
3 - Secure the "O" ring and attach the speedometer cable to the rear of the speedometer/odometer. It should be engaged in the speedometer's square hold. Tighten the drive shaft nut again.
4 - Replace the clamps that will secure the speedometer cable onto the transmission and in the engine compartment. Replace the engine cover.
5 - Drive your car slowly to be sure your speedometer is working properly. If it is, replace the doghouse. If you're stilling having problems, take the car to your mechanic.
Parts & tools -
Speedometer cable
Wrench
Screwdrivers
Good Luck.
Jul 01, 2008 | 2001 Honda Accord
Toys Logo
57 people viewed this question
Top Lego Media Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Lego Media Toy Expert? Answer questions, earn points and help others
