Question about Bialetti Chefmate Round Cake Carrier - Clear/ Red 2 Pc
Cannot get carrier to close
The lid does not fit over the red lip inside allowing me to fasten the 3 clips on the the lid to the bottom red dish part
Where can I find the instructions Manual?
To insure long life and satisfactory performance from your Nordic Ware Rice Cooker, follow these simple guidelines (microwave use only).
1. Before using your Rice Cooker wash it thoroughly by hand in warm soapy water or in the dishwasher (top rack only).
2.Foods with strong colors (particularly red sauces, tomatoes) may stain your cookware.Staining that may occur will not affect the use of the cookware.
(Cooking times may vary due to variations in microwave ovens.Adjust cooking times for best results in your oven.)
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2.Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
HELPFUL HINTS TO ENHANCE THE FLAVOR OF ANY MICROWAVE DISH:
1. Use chicken broth instead of water for added flavor.
2. Add a little butter or oil to contents.
Jul 30, 2014 | Nordic Ware Kitchen Appliances - Others
Tip
How to change lid switch in a Whirlpool top load washer.
Tools needed: Phillips screwdrive, flathead screwdriver, putty knife, 3/8 inch nut driver.<br /> <br /> Every model is different. So read though. While standing in front of washer there is a phillips screw on each side of console. Some models have a screw on each side but in back of console. Some models dont have screw so you will need a putty knife to slide under console on each side an push the clips inward and lift up on console. Once you have removed the screws or the clips lift the console and allow to flip upside down and the support hindges on the back of washer. Disconnect the quick connect the clips into another quick connect Brcketed on the frame. Remove the two gold curved shaped hinges one one each side with the flathead screwdriver.Tilt cabinet back and move it away from the washer. Unerneather you will see a quick connect with wires running to the lid switch. Remove the two phillips screws that are under the lid holding the lid switch in place. Remove the 3/8 inch nut holding the ground wire next to lid switch. There are also two hindges the hold the wires inside the lip of the frame. Pull hinges towards you enough to allow the wires to come out. Install new lid switch with the two phillips screws from the old one. Reconnect the 3/8 inch grounding wire to frame. Insert the wires back inbetween the hindges to hold wires. Snap the quick connect into the frame from underneathe. It can only go on one way. Once you have the new lid swtch installed than go back in front of washer. Place the cabinet back in place. Push the lower lip of the bottominside of cabinet back under lip of frame of washer. Gently tilt the cabinet back into place. Take your hand and make sure the glide (white plastic strips ) on the back frame line up and than put the gold hinges back in place. Than do the other side. Make sure its stable. Reconnect the lid switch quick connect. Place console back into place and make sure its snug. Put screws back in place. Now standing in front of washer. Tilt washer towards you to reset the self leveling legs. Now lift the lid and start your washer in spin cycle. Close the lid and open it until the basket returns to normal stopping mode. Keep doing this it usually takes 5-10 times increase speed of basket each time ( have lid closed longer for faster speeds). When the basket breaks are reset you will hear the breaks engage and the basket slowly comes to a stop. If you see it jerking or breaking hard The break package is not reset yet keep trying to reset. Once the break package is reset and the lid switch works good than its laundry time. <br /> <br /> Future knowledge: Lid switches go out for a few different reasons. If you drop the lid and it hits the lid switch hard it can start damaging it. Wear and tear using your washer will wear them out over time. Most common is the dropping of the lid which breaks lid switch over time. Thank you for taking your time to reason this How To and I hope this helped you in your task.
on Jul 28, 2011 | Washing Machines
Need lid for sanyo slow cooker esc 450
When my lid was accidently broken years ago I found a heavy glass saucepan lid at a second hand shop that fitted it. A lid off a casserole dish of similar size would work just as well. Ensure you measure the inside width dimensions without lip and then including lip so you find a lid with a secure fit. Good luck.
Jun 17, 2013 | Sanyo Crock Pots & Slow Cookers
On my sks rifle when stalling clip have to hold bolt back to install clip
Are you talking about a full magazine? You have to get the bolt out of the way because it is too tight? Take out 1 round and see what happens. Does it do it to an empty mag? You are not talking about a stripper clip are you? You know they don't come with magazines, the 30 rnd mags you get that are detachable have been modified some how. And they don't go in easy. Not like an AK, Let me know.
Apr 20, 2010 | SKS Rifle High-profile See-thru Scope...
How do I take the cage off so I can clean the dish?
If you don’t mind VOIDING YOUR WARRANTY, there’s a point at the bottom of the grate where an elongated spine pokes through a tiny hole in the metal dish. Use a screwdriver to pry the metal retaining lip of the dish back from that spot, and pop the grate out by applying pressure to lift the spine out of that hole, and the grate from the dish. BUT the problem is getting the grate BACK IN the metal lip when you are done cleaning. I opted to modify the grate slightly. I used a hacksaw to cut a tiny 1/8-inch section of the outer ring away from the bottom of the grate and removed the retaining spine in the same spot (from inside the ring) to allow enough flexibility to be able to squeeze the grate together to get it back in the dish’s metal lip. Now I can get the grate in and out, but when in, it is still secure enough to be able to lift the heater by grabbing the top of the grate to carry it.
Jan 01, 2010 | Presto HeatDish Compact Heater
How do i change the black ink cartridge on a lexmark x2580 printer
With printer on and connected to computer do the following:
Open top cover.
Fix top cover on open position, using the plastic sustain part located on the right side inside the printer.
Wait for ink carriage for taking position in the middle of the printer rail.
Open cartridge top cover.
Pull cartridge toward yourself and snap it out.
Do the same in reverse order to fit new cartridge.
Remember to remove cello tape strip from new cartridge nozzle.
Do alignment procedure after replacement.
Sep 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Fuji s5100 batter door cover prongs are broken off.
I have the simple and cheap fix to a frustrating problem!
Just take a tripod base and screw it into the bottom of the
camera. The square tripod base is large enough to hold the battery
cover on the camera closed without any interference.
So there you go! No tape, rubber bands or other crazy contraptions!
Cheap, Quick and simple.
Steve in Tampa, FL
Apr 21, 2009 | Fuji FinePix S5100 Digital Camera
Don't know how to install ink
Installing print cartridges
1 Open the printer, and then press down on the cartridge carrier levers.
2 Remove the used print cartridge or cartridges.
3 If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid.
Warning—Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridge.
4 If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid.
5 Close the printer, making sure to keep your hands out from underneath the scanner unit.
Removing a used print cartridge
1 Make sure the printer is on.
2 Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid.
4 Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Apr 13, 2009 | Lexmark X4650 InkJet Printer
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
Cooking Pasta:
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
Battery lid or cover
I have a s5500 with the battery lid clips broken.. fuji says ,, nope no warranty on that part ,, what a joke,,$120 dollars labour plus parts and freight for repair... anyway ,, went to jaycar (electrical supplies etc) and found a small metal clip/ fastener that I used on an existing exterior screw below where the strap is located. i then placed another screw in the lid that allows the remainding hole in the fastener to slip over, works like a charm. took me around 3 minutes to do and does not affect the grip on the camera and still alllows it to be easily opened and closed. I am most pleased i now have my camera back.
Feb 10, 2008 | Fuji FinePix S5100 Digital Camera
Bialetti Chefmate Round Cake Carrier - Clear/ Red 2 Pc Logo
82 people viewed this question
Top Bialetti Home Experts
Donni Steen
Tom Chichester
Are you a Bialetti Home Expert? Answer questions, earn points and help others
