Question about Channel Master (9537) Remote Control
Remote not working
We have changed the batteries and cannot get the remote to work anymore
Remote doesnt work anymore
Fan remote stopped working. New battery installed.
Apr 14, 2013 | Lakewood HV 18-c Floor / Box Fan
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
Remote control sometimes is working, most of the time is not working, so I have to turn it on and off manually
Tries check the tv remote battery compartment for moisture and rust on the remote battery like + - connections inside of the battery compartment?Yes?Take somethings sharp or a knife scrap all the rust out.Take a rag spray some WD40 and clean the + - battery compartment connections.Change another set of a new battery.If after this the tv remote still have the same problems,than the remote itself rubbers inner layer of the rubbers knobs probally warn out and not anymore make correctly contact to the tv remote PCB board anymore or the CPU chip itself it is slowly dying and shorting out of the tv remote CPU,remote devices are heavy dependent on it CPU chips.Or try website like Remotes.com to buy the tv original remote or very closed clone compatible one.
Sep 05, 2011 | Olevia LT32HVE 32 in. LCD Television
My remote starter doesn't work anymore...could this be a simple battery problem or more indept?
2007 Impala remote starter will not work and I must be next to the car for the keyless entry to work. I have changed tha batteries in both remotes
Oct 23, 2010 | 2005 Chevrolet Malibu
Dropped the remote and batteries fell out. Put
Check ur universal remote manual for ur tv codes.Re enter ur tv model universal codes.Ur remote should work again.Try website like 1-800-Remotes factory original.Buy an exact remote to ur tv original remote.Never care for codes agian,because u have the original remote.
May 06, 2010 | Philips Universal PH301S Remote Control
Problem With Operating the Remote
Check to see that the batteries are installed correct,,may need to reprogram...hope this was helpful...
Apr 23, 2010 | Philips SRU3003 Remote Control
Remote not working anymore for my LG 42PQ20. Ive tried changing
call LG if you think the TV is not accepting the signal from the remote the TV may have a fault in it. If you have any universal remotes try programing them to control the TV if they work but the other does not it is remote.
Mar 15, 2010 | LG 42PQ30 42 in. Plasma TV
Remote entry doesn't work anymore
remote must have lost programming, happens sometimes. only problem is that these cars require the scan tool, you need the original volkswagen scan tool that only they, and some independents like my shop, have.
Aug 29, 2009 | 2002 Volkswagen Jetta TDI
Romote quit working
take your remote very close to am radio & press the buttons if there is no reception on the radio, change ur remote
Sep 21, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Channel Master (9537) Remote Control Logo
Top Channel Master Televison & Video Experts
Peter Privates
Level 1 Expert
Are you a Channel Master Televison and Video Expert? Answer questions, earn points and help others
