Question about Simplicity Garden
Runs rough, backfires when shut off and idles rough without load
Sovereign hydo 18 v-twin Kohler engine
mickey813
  • 472 Answers
SOURCE: 27 hp kohler v-twin ohv backfires, and @
SOUNDS LIKE IT HAS BAD GAS AND THE VALVES NEED RE SET YOU MAY WANT TO FLUSH YOUR FULE AND CLEAN OUT THE CARB LET ME KNOW IF THIS HELPS
Posted on Oct 08, 2009
suzukiracing
  • 200 Answers
SOURCE: i have a john deere 325 with a kawasaki 18 hp v
Try adjusting the deck height up a little or start a the carb.
Posted on Jul 19, 2010
suzukiracing
  • 200 Answers
SOURCE: nikki carb runs real lean engine runs rough pops
Try turning the mixture screw up a little or if nothing else ive heard of the plug that goes into the carb nees to have the long needle trimmed to the height of the shorter needle in the plug
  • 640 Answers
SOURCE: my craftsman kohler 18 hp
The carb. needs to be cleaned. Pay extra attention to the high speed circuit.
Posted on Jul 13, 2011
SOURCE: i have a craftsman Dlt 3000 riding mower with a
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Posted on Aug 20, 2011
Why is my atv Honda fourtrax 350 backfireing
it sounds like its starving for fuel, when it runs lean you will get backfires and if its running rough then it may be starving for fuel at idle. Try adjusting you mixture screw and see it the engine will smoot out. Your carb my be dirty and not allowing enough fuel through it.
Feb 21, 2015 | Honda Motorcycles
I have a kohler 18 hp twin engine on a cub cadet. Backfire when shut off. Started back up sputtered. Fuel coming out by air filter. Took air filter off and ran great. What would be the problem?
Check to make sure idol isnt set too high, make sure the air filter is infact clean to prevent it from chocking itself, make sure choke is off :-) and also make sure you idol all the way down when you kill it. Make sure your spark plug is good to prevent flood, and detonation, peaceout.
May 05, 2014 | Garden
Kohler backfires
This is a timing issue. Check the flywheel to make sure that it is not loose and that the woodruff key is still present.
May 25, 2013 | Toro ENGINE - 20HP KOHLER Part 93-1169
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
92 NISSAN WITH BOGGING AT 2800 3500 RPM AND AT LEVEL SPEED 4CYL AND 5 SPEED
For this types of problem,there are few help inks to troubleshoot the problem.Click the link below to go through the troubleshooting procedure to resolve the issues :----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
--------------runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
-----------Car still runs Rough after tune up? http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
------------Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
----------High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
------------Engine Backfires? http://technoanswers.blogspot.in/2012/02/jeep-backfires.html----------- Nissan stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Nissan Pathfinder Backfires? http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
---------How to adjust rpm? http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
------------Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
----------This will help.Thanks.
Feb 17, 2012 | 1992 Nissan Pickup
Kohler 5E, initially water pump impeller no good causing overheat and shut down of motor (overheat switch killed ignition), replaced raw water pump impeller, heat exchanger stays cool, exhaust manifold...
You did not say what fuel you running the motor on??? It sounds like it may be LPG or Propane.... is so then it seems as though you do not have enough surface for evaporation...
heatman101
Jun 13, 2011 | Kohler Electrical Supplies
I have a Briggs and STatton 24 OHV intek motor on a craftsman lawn tractor. I got it on sale and when I got home it ran rough. The fuel line had collapsed or was plugged with some white powder. I took off...
It sounds like the fuel mixture is running very Lean..There are usually two adjusting screw screws on the carburettor that control the mixture. A Larger one is for the Main Jet and a smaller one for the Idle Jet. There is also an adjusting screw on the throttle butterfly to control the idle speed.
To adjust setup, start with at least a half tank of fuel, and have engine at operating tempurature (That is warm but not overly Hot). As a starting point, loosen (anticlockwise) Main Jet screw about half a turn, to richen mixture,so that engine will run without choke. Run engine at full speed and adjust main jet for highest smooth speed without engine missing due to mixture being too lean or rich.
Allow engine to idle and the adjust Idle Jet Screw for smoothest idle. Idle Speed screw may have to be adjusted if idle speed is too high/low.
Sequence above may have to be repeated to get best running. If engine hesitates sometime when sudden load is applied but then picks up, try adjusting Main Jet by 1/8 to 1/4 turn richer until it handles the load without faltering.
Aug 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
47 people viewed this question
Top Simplicity Garden Experts
Dennis Key
Dennis Key
dannydoesita
ray gallant
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
