Question about GE GSH22JSDSS 21.9 cu. ft. Side by Side Refrigerator with Slide-Out Spill Proof Glass Shelves, Humidity Drawer, Temperature Drawer, ClimateGuard and External Ice/Water Dispenser: Stainless Steel
Ge gsh22 water line freezes - GE GSH22JSDSS 21.9 cu. ft. Side by Side Refrigerator with Slide-Out Spill Proof Glass Shelves, Humidity Drawer, Temperature Drawer, ClimateGuard and External Ice/Water Dispenser: Stainless Steel
2 Suggested Answers
SOURCE: water line freeze
It seems to me like 2004 was a bad year for this GE refrig. and for me as well.....I bought one and I'm having the same problem....I have an extended warrenty and if they can't fix it I will demand a new box.....What I would like to know is why did it take four years to start to freez.....Nothing has changed in that time spand just the box freezing in the water line....Good luck all....the sqeeky wheel gets the grease....so ***** like hell.....and don't take no for an answer....
RC
Posted on May 02, 2008
GE GSH25JFTA refrigerator has stopped dispensing water. Ice is OK
change the tempt of freezer if too cold it will freeze line . try seting it for 5 to 20 deg some run below 0 and will freeze the water .. mm
Jul 29, 2010 | GE Refrigerators
GE Profile Icemaker freezing up; water freezes down inside wall of freezer; icemaker making ice, very slowly, but will not dispense. Water is still dispensing
This sounds like your water valve is not completely closing allowing water to drip and freeze. First check to make sure that the water tube going into the cup of the ice maker is lined up correctly and not causing this problem - if it is lined up correctly then replace the water valve on the back of the refrigerator that your main line is connected to.
Jul 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water line freeze up
GE makes a water line heater to correct this design fault.They are available at most part houses
Oct 06, 2009 | GE GSL25JFPBS Side by Side Refrigerator
No water from door dispenser
BAD WATER VALVE OR CHECK FOR CLOGGED FILTER
Jun 18, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice maker water line freezes
Hi, it sounds like the water valve is leaking just enough to cause the water to freeze in the inlet tube. This is the most common fix.
If I can assist you further, please let me know.
Thanks
Vic
May 15, 2009 | Refrigerators
I have a Ge PSW26LSRDSS side by side the water line freezes
The water line keeps freezing going to the ice maker? The line in the freezer? Is there alot of ice build up around the fan because of this? If so, it sounds like an ice maker malfunction is the root of the problem, and that can cause evap fans to go bad.
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water
GE's are bad for the water supply line freezing inside the freezer door. Also,a clogged water filter will cause the same thing. I have used a hairdryer in the past to unthaw my water dispense line.Good Luck!!
Feb 21, 2009 | GE GSH22JFR Side by Side Refrigerator
GE GSH22JSDSS 21.9 cu. ft. Side by Side Refrigerator with Slide-Out Spill Proof Glass Shelves, Humidity Drawer, Temperature Drawer, ClimateGuard and External Ice/Water Dispenser: Stainless Steel Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
