Question about Panasonic Viera TX-32LX70 32 in. LCD TV
Remove stand from a TX-32LE8FA - Panasonic Viera TX-32LX70 32 in. LCD TV
2 Suggested Answers
  • 718 Answers
SOURCE: How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Posted on Feb 17, 2009
How to remove the base stand from a Panasonic tx-32lxd85 tv?
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Sep 22, 2014 | Panasonic VIERA Televison & Video
Remove stand
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs are given with illustrations. Hopes that it will help you.
Aug 18, 2014 | Panasonic VIERA TX-26LXD80 26 in. HD-Ready...
How do i remove the stand off a panasonic viera tx-26lmd70 26"?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 16, 2014 | Panasonic VIERA TX-26LMD70 26 in. LCD TV
My stand by light flashes on my onkyo tx-sr501
Check output transistors for short, change emitter resistors
Mar 30, 2014 | Onkyo TX-SR501 Receiver
How to remove a stand
you have 4 screews to remove on back of your tv. 2 each side of connector panel
Apr 29, 2010 | Televison & Video
Cant get the stand off a panasonic 32 inch TX 32LXD60 to put on the wall
TX 32LXd60
Lay the tv face down on a flat surface. Do not scratch the screen ! Use a cloth.
Remove the 4 screws above the stand. Pull stand out. Replace screws.
You can get Operating Instructions from;
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
enter the model number- click search- and download the Operating Instructions . The Operating Instructions will illustrate the stand.
Apr 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
How to remove stand from panasonic tv model no tx-32 l m d 70
Place tv on its BACK,with the screw holes underneath.Remove the four screws,remove stand,and turn tv over to rest on the sceen (on top of a towel)or some other cloth so as not to damage the screen,and replace screws.The reason for placing the tv on its back when taking out the screws,is that,unless you have a magnetic screwdriver when removing the screws the are difficult to remove as they are deeply recessed.
Apr 09, 2009 | Emerson RP6248 AM/FM/TV Radio
Jan 31, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Can not remove the rest of the TV stand
I am the owner of the Panasonic TX-32LZD60, and finally managed to solve the problem myself.
So for anyone else out there with a similiar problem, you need first remove the two screws at the back of the TV which are low down. Take of the small plastic casing. Underneath you will see two rows of a total of 8 screws, which go through a black metal plate. Remove these and the stand will slide out. Not bad for a girl!!
Dec 18, 2008 | Televison & Video
Onkio TX-SR500 don't leave stand-by
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} With the unit unplugged, remove the top cover and use an ohmeter to check the 10 power transistors on the large heat sink; Q6050 thru 54 and Q6060 thru 64. If you find blown transistors (R<1 ohm from E to C) you'll need to replace them. After removing the shorted transistors, also check the associated large ceramic current sharing resistors, R6100 thru 04 next to the output transistors. These are dual 0.22 ohm, 2W resistors that typically fail open if overstressed. These are both common failures resulting from overloading the speaker outputs that will cause the proctection circuit to shut down the power supply at turn on. Good luck.
Nov 18, 2007 | Onkyo TX-SR605 Receiver
Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
