Question about Frigidaire Ovens
Lights bright dim
Oven temperature light really hard to read.Can it be easily fixed.
Rotu
  • 175 Answers
SOURCE: Oven timer and temperature display dim
You need a new display/relay board package they have come up with to solve this problem. The parts generally run about $250, and if you have it repalced by a service company, the total will be a little less than $500. The display is really easy to change by itself, but you must change the realy board with it, and it has about 40 different wires going to it. If you draw a diagram as you take the wires off, and label them carefully, it isn't that hard to do the whole job..just take your time. This is a problem thermadore/dacor ovens have had for some time. If it isn't too old you may try calling thermadore and see if they are willing to at least buy you the parts, as this is a known problem. Good Luck!
Posted on Nov 24, 2006
  • 10 Answers
SOURCE: Display Panel Light
you can get it from maytag or places like repairclinic.com. you can use their seach page you just put in the model number and look up the part number.
Posted on Dec 02, 2007
SOURCE: OVEN LIGHTS DO NOT TURN OFF.
The oven has a small button on the left side on top of the control panel. Switch it on or off. Hopefully this will solve the problem.
Posted on Mar 19, 2009
  • 114 Answers
SOURCE: Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Posted on Mar 21, 2009
  • 3 Answers
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
Posted on Jul 10, 2009
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
How do I fix the oven heat indicator light on kenmore c970 665621
If you are talking about an electronic digital display type control that is dim, most likely the only way to fix it is to replace it. Most electronic control units are not repairable in that sense.
Apr 09, 2015 | Ovens
The control panel light is very dim. It is hard
we had the same problem....my husband removed the panel and I clean the inside glass panel & it resolved the problem. It is a convection oven and steam comes out just below the clock area which I believe causes the problem.
Jul 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Dim temp. light
needs a new clock or find someone to refurb that one
Jun 25, 2009 | Frigidaire FEB27S5A Electric Single Oven
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Display light
Found out that I could replace the C3 capacitor with a 100uF 35V (high temperature - 105 C). Spent $1.69 for the capacitor and 1/2 hour taking the unit out, soldering the new capacitor in, and remounting the upper clock unit back on the oven. Works like a charm. No need to buy the whole Clock/Temp unit, waste of money.
Aug 13, 2008 | Jenn-Air W30400P Stainless Steel Electric...
Light for the temp. & time very hard to see can it be made brighter?
then you will have to replace the eoc the electronic oven control as long as it was working id use it till it wasnt then replace it
Jan 19, 2008 | Jenn-Air JJW8530C Expressions Collection...
Dimming temperature and clock light on display window
I found capacitor c3 (68 uf 35 volt) had leaked and dried up, causing the display to fail. I unsoldered and tested c1, c4, c7, and made sure they were good, using a digital multimeter with the ability to test capacitors. C3 also had visible signs of leakage. Works like a charm again, and the display is bright like new!
Dec 30, 2006 | Thermador SC272T Electric Double Oven
Ovens Logo
79 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
