Question about MasterForce 6"X9" Belt/Disc Sander
Table assembly for 6 x 9 Disc Belt Sander
We're thinking of purchasing a Masterforce 6 x 9 Belt Disc Sander and want a second table assembly so we can use both the disc and belt sander without switching the one table that come with it. Any advice on how and where to find just a table assembly?
How to fix motor delta belt disc sander
What is it doing or not doing, when u turn on the switch, either the switch or motor is probably bad or you have too much tension on the belt.
Aug 22, 2014 | Delta 31 695 6" Belt/9" Disc Sander
Ryobi belt and disc sander
It's only a month old. Take it back for a repair/replacement under warranty.
Jul 01, 2017 | Tools & Hardware - Others
I'd like to purchase a table support (for the disc
Just the support is not available. You have to buy the complete Table. Its PN 2610959405
its about $24.00 You can get it Here
Jun 29, 2011 | Tools & Hardware - Others
The blade isnot square with table
You can adjust the trunnion assembly from the bottom side of the table. Most saws have 6 bolts that bolt to bottom of top. if you loosen all six bolts then shift as nessessary to align to top top, then retighten the bolts. The holes in the trunnion assembly brackets should be oblong to allow this ajustment, Jim
Jan 23, 2010 | Craftsman 10" Table Saw
Installing belt on sander
Remove table assembly.
Remove pointer and then slide cover up and out from dust reflector.
Release belt tension by pushing tension lever toward idler drums.
Note: there may be an arrow on the inside of the belt.
The arrow should point in the direction of belt travel to ensure that the splice in the belt will not come apart.
Slide new belt over the drive and idler drums; center belt on drums.
Push tension lever towards drive drum to tension belt.
Hope this helps.
Oct 04, 2009 | Tools & Hardware - Others
It seems the sanding table has frozen to the eccentric on my orbital clarke floor sander. Any recommendation on how to get apart. I need to replace the 4 upper bolts with rubber washers. I have tried...
Go to Americansanders.com and under the orbital sander click on it and the manual is 38 pages long, the parts explosion is towards the back of the manual but it should show you how to disassemble this tool so you can get to the bolts that you need. Let me know if you need more help
Sep 30, 2009 | Clarke Floor Sander Floor Sander Orbital...
31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Jan 27, 2009 | Delta 31 735B 6" Belt, 12' Disc 3 Ph...
BROKEN RUBBER BELT FOR BELT SANDER
Maybe you can use a linked belt to replace it. Check the width of the old drive belt, and give these folks a call: Lee Valley
Nov 14, 2008 | Tools & Hardware - Others
Wood working sander?
belt because it work realy good use ing the circle scraches the wood and the beld dos not
Sep 28, 2008 | Milwaukee Tool Milwaukee 6125 Sander Ro 5...
MasterForce 6"X9" Belt/Disc Sander Logo
Top MasterForce Tools & Hardware - Others Experts
Are you a MasterForce Tool and Hardware - Other Expert? Answer questions, earn points and help others
