Question about Building Materials
LEARN CODE ON AEI DK 9610
TRYING TO ACTIVATE LEARN CODE ON KEYPAD FOR DUAL BUTTON REMOTE CONTROLER. I have the garage door merlin working though don't know how to activate steel gates withAEI DK 9610 SUPER KEYPAD. LEARN BUTTON NOT OBVIOUS.?
SOURCE: Lack of range on Garage door remote
There is a short wire hanging down from the back of the opening motor -- pull this down as far as you can and bend it so it is pointing toward the garage door. This wire acts like an antenae.
Posted on Dec 30, 2008
  • 244 Answers
SOURCE: keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Posted on Jan 28, 2009
  • 3197 Answers
SOURCE: garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Posted on Aug 04, 2009
  • 3197 Answers
SOURCE: remote code for a merlin power lift
I think you will have better luck checking around the Australian forums for help with this door opener.
Posted on Apr 14, 2010
swolfinor
  • 504 Answers
SOURCE: garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Posted on May 24, 2010
Trying to chg code on garage door opener have cleared by following instructions. I am trying to reprogram remotes and is not working
Hold the button down on the remote while you press and immediately release the smart/learn button. Do this for each remote you have.
Dec 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Merlin powerlift-model 2500L Garage door and cannot find the Learn Button to program my new remote. Please help...
This is a foreign design but here is what the instructions say to do.
Remove the light cover then remove the colored plastic rectangle strip located underneath. This will reveal a red Learn/Delete? button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode. 2. Push the big button on your remote for 2 seconds 3.Push the little button on your remote for 2 seconds Minimum of 1 second is required between each action Your remote will now operate with your motor b) Overhead Doors Remove the coloured plastic rectangular strip located next to the Merlin label on the front of the motor. This will reveal a red Learn/Delete button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode 2. Push the big button on your remote for 2 seconds 3. Push the little button on your remote for 2 seconds *Minimum of 1 second is required between each action Your remote will now operate your unit. Thanks BB
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Programing garage door opener
Hold the button on the remote and press and immediately release the smart/learn button. Do this for each of your remotes.
For the keypad press and immediately release the smart/learn button. Walk over to your keypad and key in your 4 digit code and press enter.
If these instructions don't work you have a bad logic board.
Dec 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keyless remote will not learn new 4 digit code
Press and immediately release the smart/learn button and walk over to the keypad and key in your 4 digit code and press enter. If this doesn't do the job your keypad is probably bad.
Oct 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Reprogramming Garage Door Remotes
I think you are holding the smart/learn button too long. Press and hold the button on a remote and then press and immediately release the smart/learn button. Do this for each remote.
Oct 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Aug 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't set code for keypad and remote...one works, then when other
You have used up all of the remote spaces on the opener. You need to reset the remotes. Press and hold the learn button for 8 seconds. This clears the memory for all remotes. Then press and release the learn button and then press the button on the remote. The light will blink once on the opener. Repeat this step on the other remotes.
Feb 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Control won't work.
How does everything look well? How old is unit? Did you push learn button for 10 seconds. Then pusj for 1 second and activate a remote button. lightbulb on motor should blink. if so, hit learn again for 1 second and push button on other remote. Do you have a LOCK or VACATION button. Make sure it is off . Is light on wall console blinking. you have remotes locked out.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door keypad & remote
You need to sync both. I have a LiftMaster. If you want to change the code on your keypad you need to open up the garage door motor compartment where the light is (mine is in the back). Press the learn button, within 30 seconds enter the new code on your keypad and hold down the enter button for several seconds until the light on the opener blinks to tell you it has learned the code. Test the new code to see if it works. If the new keypad code works, then try the remote. My remote will not work after I reprogram the keypad. If the remote does not work (check battery) then climb back up the ladder and press the learn button on the garage door motor again, press the remote button and hold down until the light blinks again and the opener has learned the new code. This process works when I need to sync my remote and keypad. Good luck, I hope this helps.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Help w/ programing keypaqd along w/remotes
I press the learn button on the door motor. I wait a few seconds and press a new 4 digit code into the keypad, hold down on the "enter" button for several seconds so it learns the code. Now the remote will not work. Press the learn button again, press the button on the car remote until the light on the motor blinks. Both should work after that.
I have Sears LiftMaster products. Hope that helps.
Jul 20, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
134 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
