Question about Casio Ceptor Watches
Blinking display watch keeps blinking on Jan 1
The chronograph function on my husband's Timex Ironman Triathlon 30 lap watch disappeared the last time he reset the clock time. How can he find it again?
press hold set button till display blinks, then press mode key till you have display you want then press set key to keep selected display.
Feb 14, 2016 | Timex Watches
Lcd display
Try this! otherwise repair the display:
- Remove the battery from the watch and keep your watch in bare sun for at least 1 hr and then press the display at center for 3-4 times. This should work
Note: Must remove the battery first
Mar 24, 2014 | Casio Watches
Under the settings, limits, the limits on the max HR stop @ 100. I want to increase the setting on max hr but it stops @ 100 and then returns to 18. help [polar F4]
Go into settings.
Press the center button on the right hand side of the watch 1 time you will see settings watch time & date appear in the display.
Press the bottom button on the right side of the watch1 time to get into the TRAINING SETTINGS FUNCTION.
When you see TRAINING SETTINGS in the display press the center button on the right side of the watch once.
You are in TRAINING SETTING mode.
Press the bottm button on the right hand side of the watch 3 times until you see
ZONE LIMITS displayed.
When you see ZONE LIMITS displayed press the center button on the right side of the watch 1 time to enter into the ZONE LIMITS FUNCTION.
Now, you should see the lower end heart rate limit number blinking.
To adjust this number use the top button on the right hand side of the watch to increase this limit or lower button on the right hand side to decrese it.
When you have it set where you want it press the center button 1 time to save that setting.
Now you should see the upper limit number blinking.
Follow the same steps to set the upper heart rate limit.
When you have pressed the ceter button to set the upper limit you have completed setting the heart rates limits and the display should read: LIMITS SET!
Feb 13, 2011 | Polar F4 Heart Rate Monitor Watch
On my Kirium F1, the digital display keeps blinking. How do I make it stop, or is this the signal that I need a new battery?
Yup, it means it's time to change the battery. However, if it's blinking despite having a new battery, it could be because the time and date needs to be set.
Here's a copy of the manual for more info :-
http://www.mediafire.com/?qgq1p3329sbe7s1
Hope this helps.
Jan 10, 2011 | Tag Heuer Kirium Formula 1 Chronograph...
Bought a cheap digital watch at Academy. I dont see a brand name on it only "sport". The band is sewn onto the watch so cant see the modle #. Please help me figure out how to set the darn thing!
mcdevito75 here, we"ll try, Press 1 button at a time, when you presss mode the display will blink, you may not have a button for mode rather an indent that you"ll have to push in with a toothpick, once the display is blinking press set for each function, Hour, Minute etc, after each function is set press mode to move on to the next function. When done press mode to retirn to staedy display.
Jun 27, 2010 | Watches
I have a Series 118 Pierre Cardin Quartz alarm with 3 buttons: Light, Set and Mode; I can't figure how to set/change the time
mcdevito75 here, The mode button is the button you need to depress to set the mode of the watch. Depress the mode button once, see if anything on the face is blinking, if it is use the set button to adjust the time/date You may have to depress the mode button twice or depress and hold down the mode button a couple of seconds to get the face/display of your watch to blink, after you make 1 adjustment to move to the next depress the mode button again until you get to the next adjustment, or the next function to set on your watch. After you"ve set all the functions depress the mode button again to stop the blinking a show a steady display.
Jun 12, 2010 | Watches
Athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Apr 30, 2009 | Watches
CHARGE LIGHT FLASHING
it means the battery is going dead.
Mar 02, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Sep 28, 2008 | Watches
Dakota atomic wrist watch sold by National geographic
s1 is the top button and s2 is the bottem button
Feb 20, 2008 | Dakota 2786-6 Wristwatch
Watches Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
