Question about E Sky Flight Simulator Training Kit
Propel helicopter propeller not spinning
The bottom propeler is not spinning
I have the Air Hogs Helix X4 Stunt Quad Copter and it flys to one side sometimes. One of the propellers will periodically stop. When I turn the throttle off that same propeller stops spinning earlier then...
I have the same problem, two props spins freely when I spin it by hand in switched OFF position. and in ON position, when I turn down the left control to zero they continue to spin while other propellor stops. I know this info is not a solution but if there was a "how to replace motor or propellor" site. maybe I'd find a clue to why the props drag and get it to spin freely like it suppose to be. I could probably put a video together on that topic but if there is already one out there let us know.
Sep 22, 2013 | Spinmaster Air Hogs Helix 360 Helicopter
I cHarged the helicopter and can get the directional Propeller to spin but cAnnot get the main throttle proPellers to spin. Help
try to play around with the trimmer.. i had the same problem but then guessed it was the trimmer and iwas right!
Dec 25, 2010 | JCPenney Gyropter RC Helicopter
Heli will not climb above ground effect, battery tests ok, axles in balance no vibration, just will not climb
I also have this kind of problem with my apache. The upper propeller must spin faster thatn the lower propeller if not the heli would just spin on its tail although maximum power is achieved. The solution is to check the connection of the gears and the axle of the upper propeller which is located at the bottom of the helicopter. remove first the battery pack to see clearly the connection. try to turn the upper propeller a few turns and see if the axle, gear and the metal connector is sliding. A fixed my heli buy putting a permanent glue on the axle, connector to the gear and whalla. it does not slide. Most problems of this model is the gear of the upper propeller, often times loosened specially during crushes. This will a lot help you as your heli would have power on the upper propeller for lift off. Happy flying.
Gerry1abe.
Mar 07, 2010 | Apache Colco Ah 64 Longbow R/C Helicopter
Hi my apache bottom wings are good but top wings dont spin they just sit there they were fine the first flight untill i crash it
Please check the connection of the axle of the upper propeller. Turn the heli upside down and spin the upper propeller manually, try to see if the gear turns if not there is a loose connection. You will find 2 small screws near the gear, unscrew one of them and push the axle then back in place, tighten the loosened screws. Turn the upper proppeller manualy, a few turns will do ansd see if the gear turns simultaneously with the propeller. If it still does not turn, apply a permanent glue to the gear and the axle. This will sure have your heli on flight.
Gerry.
Dec 29, 2009 | Apache Colco Ah 64 Longbow R/C Helicopter
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
E Sky Flight Simulator Training Kit Logo
Top E Sky Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an E Sky Toy Expert? Answer questions, earn points and help others
