Question about Jenn-Air JCD2295HES Side by Side Refrigerator
My Jenn-air model jcd2295kes is leaking a small amount of water which trickles down the freezer door below the water and ice dispenser
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
  • 3422 Answers
SOURCE: ice maker doesn't work. changed filter. light on ice maker door still on.
Just check THIS link out.It will solve your problem.
From my side i believe it is the control board which has to be replaced and it will work again.
Goodluck..
Posted on Apr 05, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Posted on Jun 11, 2008
docjohn174
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Posted on Feb 13, 2010
I have a side by side refridgerator freezer. I have just connected the water to the ice make / water dispenser for the first time and just a short trickle of water flows into the ice cube maker - not
I would guess that you need to purge the air out of the lines and system for it to work correctly. You can hold down the water dispenser for awhile to help, but if you do nothing, it should purge itself over the next few days.
Jan 07, 2012 | GE Refrigerators
Our Jenn-Air JCM22 side by side refrigerator water dispensor allows water condensation to run out from behind the rubber boot that houses the on/off water dispensing press switch. In humid conditions this...
HI,OPEN THE FREEZER COMPARTMENT CHECK IF THE DISP ICE DOOR IS CLOSIN PROPERLY ALSO CHEK THE ICE MAKER FOR WATER LEAK,IF HOT AIR IS FILTERING THRU THE DISPENCER ICE DOOR WILL MAKING THE ICE BUCKET ICE TO MELT AND LEAK WATER,IF YOUR ICE MAKER IS BAD WILL LEAK WATER, IF YOU CAN'T FIND THE PROBLEM GET EXPERIANCES SERV TECH TO DIANOST THE PEOBLEM..
Feb 21, 2011 | Jenn-Air Refrigerators
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
Water is trickling down through where the ice dispenser depressor sticks out of the freezer door. The ice is getting soft. Water is trickling down under the framing for the ice /water dispenser on the...
By not being there seeing the amount or flow rate i'm not sure but from where your saying it's coming out, It sounds like this is either condensation from behind the framing or the flap that closes when your not getting ice is not closing. This could be a broken spring but if the flap is closing. There is a heater blanket behind the framing that heats and dries the condensation out. If it goes out, water will leak out from where your describing. Try going to www.partselect.com and enter your model number. This should bring up diagrams of your unit. See if there is a heater that goes in your model. if there is, I'm pretty sure it will be bad and need replacing.
Dec 21, 2009 | Frigidaire Refrigerators
Water dripping from inside of freezer compartment.
The condensate drain has a blockage further down and possibly in one of the turns as it leads down to the pan below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie2.gif that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
- Click Here=> HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Sep 24, 2009 | Jenn-Air JCD2389G Side by Side...
I have a Jenn-aire JSD2695KES - it is a side by side, a couple of years old with an ice maker. Ice gets jammed in the last ice spot in my ice maker. It has been getting stuck in other spots lately, too,...
That sounds like a frozen over water fill tube due to a leaking water control valve. You may need to pull the ice maker out to see it but what you described is what happens when this happens. If frozen over the water will still come out on some models because there is a split in the top of the fill tube. Or something needs corrected on the amount of water time is OK for your ice maker. let me see if I can find the service manual for your model Be back soon Sea Breeze
Sep 21, 2009 | Refrigerators
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
29 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
