Question about Gaggia Syncrony Espresso Machine
Gaggia academia is leaking coffee - Gaggia Syncrony Espresso Machine
5 Suggested Answers
JohnnyBeans
  • 223 Answers
SOURCE: Gaggia syncrony compact coffee machine
It is very hard to say where the leak is coming from. If you can open the case of the machine a physically notice where the water is leaking from then we can tell you if you can repair it yourself or if you will have to find a service center.
Authorized Gaggia Repair Center
Cerini Coffee Services
New York, USA
www.cerinicoffee.com
Posted on Sep 12, 2008
EsWorld
  • 1618 Answers
SOURCE: gaggia syncrony compact leaking water where
If you remove the tank, does it leak? If yes then check the spring loaded valve under the tank, also check the O-ring for damage.
Posted on Jun 06, 2009
  • 1089 Answers
SOURCE: Gaggia Titanium coffee maker leaking water
What color is the steam manifold? It is located under the black cover with the trough in back under the white tube. If its white or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand. But its going to have to be replaced.
If it is silver you probably have O-rings that need to be replaced. I would use the black O-rings, not the red. The red ones are a little smaller and can leak.
Posted on Dec 01, 2009
EsWorld
  • 1618 Answers
SOURCE: water leak causes the main power to trip. can you
Yes it can be repaired, I would suggest getting a rebuild O-ring kit for your machine, it comes with all the gaskets and O-rings that you will need for the machine.
Posted on May 30, 2010
Hi, have a gaggia newespress006, gaggia expresso pure machine. I have descaled it and tried to do a backwash with the holder with no holes and it still continually leaks after using it for coffee? An
Look for easy stuff first. If you can get the top cover off, see if any of the piping/tubing joints are leaking.
If it leaks around the portafilter while making coffee, you need to change the portafilter gasket.
If water dribbles into the portafilter after making coffee, replace the three way valve.
If it is dribbling water in to the catch pan it is either the three way valve that needs to be replaced or the boiler gasket leaking and needs to be replaced.
Nov 20, 2014 | Gaggia Coffee Makers & Espresso Machines
Gaggia accademia
Most likely a connecting pipe might have come loose or leaked, boiler leaking might also be possible
Jul 17, 2014 | Gaggia Coffee Makers & Espresso Machines
Can an owner of a gaggia academia get a repair manual for it. i need to get into mine and see why its leeking
You can buy one from america. http://www.shop.partsguru.com/Gaggia-Accademia-SUP038G-Service-Manual-SUP038G-Service-manual.htm Ive got a problem with mine too and thats the only one i found so far
Jul 23, 2013 | Gaggia Espresso Machine Academia Model...
My Gaggia Synchrony is leaking - If I remove the water catch basis, I can see a drip. We have used this machine every day for years - can the problem be fixed easily?
HI
There is a panel behind the brew unit, that has 2 screws. Remove it and clean the coffee residue behind it. That is what drains the pressure relieved after brewing, and has coffee residue that can build up and cause the leak. It should leak into the drip tray though, except when you rremove it.
Oct 23, 2010 | Gaggia Syncrony Compact Coffee...
Water leak causes the main power to trip. can you
May 30, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia syncrony compact leaking water where container joins coffee machine jim
Jun 06, 2009 | Gaggia Espresso Dose Espresso Machine
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
New York, USA
Jul 22, 2008 | Gaggia Baby Espresso Machine
Gaggia Syncrony Espresso Machine Logo
23 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
