Question about Diesel Durostar 6000 Watt Portable Power Generator
Generator not giving power to control box - Diesel Durostar 6000 Watt Portable Power Generator
How to hook up power cord to salt generator
Hello, Garland -
The various CircuPool User's Guides do not have information on the wire hook ups for the control box:
http://www.circupool.com/circupool-userguides.php
Nor does the CircuPool Online Help page have that information:
http://www.circupool.com/help.php
Nor do the CircuPool Installation instructions:
http://www.circupool.com/how-to-install-a-salt-chlorine-generator.php
Therefore, I suggest you contact CircuPool directly and ask for the wire connection instructions:
http://www.circupool.com/compare-chlorine-generator-systems.php#contactForm
Note: Once you have the instructions, be sure to keep them in paper format where you can find them again easily for future seasons. :)
Best wishes.
Mar 03, 2018 | Electrical Supplies
Sparking in power box when we use the generator and trips the braker
When you say "power box" do you mean the main breaker box in your house? Is the generator hooked up to the breaker that you say trips when the generator is on? There is a short somewhere. First check the generator. Is it running OK. In other words if you plug something into the generator receptacle directly, does it work? If the generator itself works properly, then check the wiring from the generator to the circuit breaker. DO NOT use the generator until the problem solved = safety first.
Jun 12, 2014 | Cars & Trucks
Honda Powerboss Generator. The engine starts & runs great but generator does not provide power to the outlets. Problem is intermitten but I can tell when it is not going to work by taking the load...
hi
problem with voltage regulator/ generator as when this functions properly it will raise engine speed hence giving out the power out put required
Nov 12, 2017 | Honda Electrical Supplies
Installing load panel & inlet box
The bigger lugs will tighten just fine. Go that route and it will be easy to upgrade! If it seems way large when you put the wire in, strip the wire back and double it over. The # 6 may be a bit big for the 30 amp lugs. 30 amp circuit is usually # 10.
Sep 08, 2009 | Reliance Controls 50-Amp Power Inlet Box...
1955 Harley-Davidson generator wiring diagram.
Tyhe F side id the Field coil. Follow whatever directions you have for the control box.
Apr 07, 2009 | 1993 Harley Davidson FLSTF Fat boy
240 volt supply not working
there should be a switch to chane over
Jan 31, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman 7000w gen. I have 120 on only one side of my 240 plug. I disconnected wire assembly from control box.. Could get 120 out of various combinations of the 4 wires but never 240. Should I be able to?...
At the wire assembly there should be 2 white and 2 black wires, a white and a black are the ends of one 110v winding. With the 2 white wires connected together you should get 240 from the black wires. This sounds like it is a problem with one of the circuit breakers in the 240v outlet in the control box, check them with an ohm meter.
Regards,
Carl
Jan 31, 2009 | Coleman Powermate Powermate 5000W...
Commercial generator 20kv not working properly
Troubleshoot like this:
1 - With the generator control in Auto, jumper from terminal 3 to 4 on the control board. Generator should start without transfer switch doing anything. If it won't you have a bad controller board.
2 - If the Generator started, remove the jumper - controller is OK. Next go to the 1st transfer switch and find the remote start terminals. These will be the same wires that were connected to controller terminals 3 and 4 at the generator. Use your jumper wire to connect them and see if the generator starts, if not there is something wrong between the switch and the generator, probably a broken wire.
3 - Don't forget to check the other switch, the remote start terminals of the switches connect in parallel across controller terminals 3 and 4 so that either switch can start the generator.
4 - Each switch should have some sort of a test button/switch, power down as much of the building as you can, then run the test function of each switch one at a time. Don't stand directly in front of the switch while you do this.
Nov 20, 2008 | Electrical Supplies
No power output
Hi, check your exciter cap inside the control box as it probably is knackered, Replace it with a new one.
Or if the unit was severly overloaded the windings are probably fried.
Oct 21, 2008 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Diesel Durostar 6000 Watt Portable  Power Generator Logo
12 people viewed this question
Top Diesel Electrical Supplies Experts
jdthefixer
Joseph Mueller
Joseph Mueller
cwradio73
Are you a Diesel Electrical Supply Expert? Answer questions, earn points and help others
