Question about Dryers
Dryer doesn't heat
The dryer doesn't heat up at all. It just blows cold air . everything else seems to be working. I made sure the vent was clear of lint
    Sergeant:
    Champion:
  • 214 Answers
Well with the info posted here all i can tell you is to cheak the breaker panel on your house it would be a double 30 amp breaker.It may have kicked out on1 side just snap it on and off a few times then try it.If does not work let me know give me the make and how ild .that will help me help you :
Posted on May 20, 2009
  • tom wright
    tom wright May 22, 2009
    sorry if i was not helpfull i was trying to give you the ideas that will get you going .What i mentto say is how old the dryer is and make so that i can give you better help on the problem.Sorry if i came out rude in anyway
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Dryer not heating
If your dryer won\'t heat up the first thing to do is clean out the vent from the back of your dryer up to the roof. (or where ever your vent leads to). You will have to clean it our from both ends. Use a vacuum cleaner that has the ability to switch and BLOW air rather than suck air to blow it through. This usually fixes the problem because there is no air flow and it takes HOURS to dry. If that doesn\'t work then look at the back of your dryer. MAKE SURE IT IS UNPLUGGED IN EVERY EVENT! Then disconnect the wires one at a time and clean and reconnect to make sure you have a good solid connection. Plug back in and see how if it works.
Mar 10, 2014 | Roper Dryers
My Whirlpool Super Duty Imperial drier won't produce heat. I made sure the outside vent was unclogged; it is blowing cold air.
When a dryer doesn't heat, either the heating element is bad, or the flap inside the venting of the dryer is opened allowing air to bypass the dryer instead of blowing the air into the dryer.
Jun 24, 2010 | Dryers
My dryer is working, but it's not heating
pull the vent line off the back of dryer and see if it helps,also the duct that the lint filter slides into could be loaded with lint,when was the last time you cleaned out the dryer?sounds like from what you said when you had the top off it worked better because you had better air movement with the top off.go out side and check the vent,if it's a long run from the back of the dryer to the outside vent i use a leaf blower to blow out the vent line,you also need to vac out the inside of dryer where the motor is,if you have a shop vac blow off the motor and blow through the inside vent to clean out the heating duct and vac out the back of the drum,you should take it apart and clean it out once a year so the dryer will run correctly
Mar 27, 2010 | Frigidaire GLER341A Electric Dryer
My dryer turns on but throughs out cold air
In most cases, a failure to heat is caused by a blown thermal fuse or high limit thermostat. Usually it is the fuse, but the fuse may be blown due to a defective thermostat. To find the location on yourspecific machine (and purchase the parts) try www.appliancepartspros.com To test the fuse, WITH THE MACHINEUNPLUGGED, put an ohmmeter or continuity tester across the fuse with it's wires unhooked. It should have continuity. If it is open, replace it. If the thermal fuse blows, it is fairly common to find the dryer vent partially blocked as well. Make sure it is clear. Thermal fuses are fairly cheap, but you don't want to have to replace it every other week.
Jan 03, 2010 | Washing Machines
Dryer taking too long to dry
If you can get the dryer outside, blow it out from the bottom with compressed air (using an air compressor or even a leaf blower). make sure the vent is clear and has no lint buildup. make sure the burner unit is also lint/dust free. If it is still heating, that is good news, and it is most likely a "breathing" issue. it also could be an issue with your gas pressure, however that is very unlikely. Best wishes in this project.
Oct 22, 2009 | Kenmore 73952 Gas Dryer
My dryer stopped heating. Everything else seems to work. It still runs, but only feel cold air.
Electric or Gas?
If electric, the element is gone or a fuse blew or the airflow thru the dryer is restricted or a sensor is bad and 'lying' to the CPU. Check the filter, check the hoses for lint, check the outside vent flap to be sure it isn't stuck (possibly painted) closed. The air has to BLOW a certain CFM or neither ELEC or GAS type will turn on.
If Gas, the pilot isn't lit or the electronic ignition isn't firing or the gas supply valve is bad/stuck or the thermocouple that tells the CPU that the 'heat is on is 'lying' or the sensor that tells the CPU the Air movement is OK' is bad.
My dryer wouldnt heat because a thermocouple in the exhaust pipe was lying - stuck ON and telling the dryer it was already hot enough. ;-)
If you do the troubleshooting, do NOT forget to unplug first!
Mar 26, 2009 | Dryers
Dryer heats for 10 minutes and turns off
Turn the dryer on, go out to the where the vent exits the house. Feel the air coming out, and it should blow very strong, and for the total diameter of the discharge. If it doesn't, the vent pipe is plugged, or the connection hose from wall to dryer is crimped/collapsed when pushed back to the wall.
Also make sure lint filter is clean, and the grill inside the dryer where hot air enters is clear.
Reply back your findings and I can help you more.
Jan 29, 2009 | Dryers
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Dryers Logo
90 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
