Question about Pioneer GM-5000T Car Audio Amplifier
Wiring speakers to bridgable amp
I would to hook up one sub and two speakers to my bridgable 4 channel amp and hook up two speakers to my pioneer cd stereo(4x45watts). Is this OK?
  • 709 Answers
I just answered this one
Posted on Oct 23, 2007
  • Greg Stokes
    Greg Stokes Oct 23, 2007
    Yes, you can hook this up.  It is not great.  If you have individual channel adjustments to set the filter for the sub and separately set the filter for the 2 rear speaker.  It can work fine for you.
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Sony X-Plode amplifier. NOT working
It is possible if the model amp you have is bridgable to 1 channel. Usually when you bridge an amp you will need to hook one wire to the positive side of one channel and the negative side to the other. You will need to consult you user manual for the amp or get the manual from the sony website for instructions on how to bridge the amp or if the amp is even bridgable.
Oct 11, 2009 | Car Audio & Video
Troubleshooting amp setup
You probably need your remote wire re-hooked and make sure the ground wire is good and the remote wire is connected to the right wire(the red wire).
Jan 05, 2009 | Car Audio & Video
How many speakers can I use?
This should work if channel 3 & 4 are bridged at 4 ohm.
channel 1 should be stable at 2ohm
channel 2 should be stable at 2 ohm
You can hook up the right side speakers together ( + with + and - with - ) . same thing with the left side. this will give you 2 ohm each channel. this will cause your amp to run hot (this might be tuff on the amp). It will give you right (2 speakers) and left ( 2 speakers ), no front and rear adjustement if you need to balance your sound. I think you should be better buying another amp for your sub and take your 4 channels for your 4 car speakers. this amp as a rca output that can feed the other amp ( sub amp ). it is possible to do it.
Good luck
Nov 11, 2008 | Alpine MRP-F250 Car Audio Amplifier
Subwoofers
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Sub not playing to full potencial
you haave either connected it incorrectly.make sure the ohm of the speaker matches that of the amp ..connect the positive coil to the positive coil at the back of the sub and the same for negative .then run your cables to the amp .you should only have one positive cable and one negative cable .this connection will create a 2 ohm connection make sure the amp can handle that load .prefarably using a 2 channel bridgable amp or 1 channel monoblock
Feb 20, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Need help
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
Witch is better
hi there. ill start with the wiring. you should have a blue remote lead going to the back of your head unit, the power cable running straight from the amp to the battry, the earth should be earthed in a fairly decent place, any metal inside the car realy, and then your wires pos and neg from the amp to the subs. the reason why the kenwood might not have much base on it is to my knowledge, there should be a switch somewhere on the amp that will increase or decrease the power input for the speakers, if this is set very low then hense why theres not much base comming from them. if the amp is on and its giving something to the subs it probably isnt the wiring. try checking the amp for the switch first, if you cant find it try the pioneer amp and see if theres any diference.
dont hesitate to contact me if you get stuck
cheers, adam
Oct 31, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-5000T Car Audio Amplifier Logo
168 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
