Question about Microwave Ovens
Need install guide for bell'o 7615b - Microwave Ovens
How can I get my microwave to actually heat when everything else (cook time, power level, clock, etc., are set and seem to be running?
Sounds like the MW Emitter is not working or the wave guide is disconnected. If it is the wave guide then you can fix it yourself if you take the rear cover off. It is the pipe, which in cross section is quite rectangle shaped with rounded corners. It should be connected to the emitter at one end and the opaque guide cover at the other with no breaks. If the emitter is faulty then seek professional help.
Oct 19, 2014 | Hamilton Beach 1.1 cu ft Digital Microwave...
Flame coming from waveguard of Belling cjss25 Thanks
HI
Sounds like you have lost your magnetron and wave guide cover was dirty. Its time to replace the microwave...
Sorry for the bad news
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 28, 2011 | Microwave Ovens
Hi i put a plate in which has a gold rim on it, Only for a few seconds ,has this blown the fuse inside the microwave? I have changed the plug fuse but no joy, The microwave is only about 1 year old
WORKING ON MICROWAVE OVENS IS DANGEROUS!!
That said, since you've already changed the fuse it's likely the magnetron has shot itself in the eye and died. If you want to press on and troubleshoot, here's an excellent troubleshooting guide:
http://www.repairfaq.org/sam/micfaq.htm
Again, be sure to discharge any capacitors.
Mar 03, 2011 | Belling STW25 900 Watts Microwave Oven
The ovens in my belling classic ninety deluxe will not heat beyond 110 degrees. what is wrong with it?
Probably thermostat is faulty.
Employ a Belling Approved appliance engineer to check and replace it if in needs replacing.
Jan 04, 2011 | Belling Microwave Ovens
I need an installation guide for a Kenmore microwave hood combo model # 80083?
Go to managemyhome.com and type in the model number under the "Manuals" link. There are several installation guides available to choose from in a .pdf (Adobe) format that you can download, or print for FREE. I hope this helps you.
Oct 28, 2009 | Microwave Ovens
Instruction manual for Belling Combi oven BEL-CJSS25
Did you try this?
Lines are open Monday to Friday 8am - 6pm and Sunday 10am - 2pm.
Belling Customer Care: 0871 22 22 503
Or maybe this?
Belling Product Helpline
0871 22 22 635
Product Helpline Open Times
Monday to Thursday
9am - 5pm
Friday
9am - 4.30pm
Spare Parts
0871 22 22 506
Nov 24, 2008 | Belling Microwave Ovens
Notification bell
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, there may be a setting on your controls to turn the tone on and off, or it may need to have the control panel repaired. We do that for $39.95 in most cases.
You can download Maytag owner's manuals and installation instructions here.
Sep 18, 2008 | Maytag MMV4205 Microwave Oven
Bought a floor model, need to remove the U bracket
You can download owner guides, installation guides, etc. for this model here:
http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLMV169DC&User=&Search=Search
(you will need to copy & repaste whole the URL together if it breaks after the question mark)
Oct 13, 2007 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
12 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
